Question about Aquatronics AMS602WR Coaxial Car Speaker
My shower temperature is unstable , keeps going hot and clod
    Novelist:
  • 99 Answers
I think you posted in the wrong area, but, you might need to replace the mixer valve in the controls of the shower, this is what controls the temp while it's running, they get old and need to be replaced every so often. I don't know how your shower is set up, or what brand it is, but it's easier to do if you only have one control knob (one controls both hot & cold), than if you have two seperate(one for hot, one for cold).
Posted on Oct 02, 2009
We have a problem with our Rinnai 24 hot water service. Hot water goes hot and cold. Does not keep to 38 degrees temperature when showering.
Do You know if there is an anti scald valve in the shower valve? If so it may be scald up with corrosion and need replaced! To see if this could be the problem, flush the toilet next to the shower while the shower is running. If temperature changes in shower I would say that is your problem! If You need to replace it, it would be cheaper to do it yourself! They should be videos on Youtube on how to do it! Good Luck! Regards!
Jul 14, 2017 | Rinnai Water Heaters
Shower temperature fluctuating and will not stabilise
You haven't provided much information to help narrow down the source of the problem.
Is the flow of both hot and cold water flowing freely? Are the water lines not clogged internally with corrosion or residue? Is it possible that the water is being diverted such as in an apartment building or to an outside spigot (sprinkler system) or kitchen faucets (dishwasher)?
Is your water heater temperature setting correct and is it supplying sufficient hot water flow to the shower?
Do you have a temperature balance cartridge in your shower faucet? If yes, it could possibly be faulty.
Nov 07, 2014 | Home
Why do we need to have to continuously adjust the temperature of the water when we're taking a shower. We have a new Rheem gas .hot water tank
It *may* not be a problem with the water heater itself necessarily. When you say "keep adjusting the water temperature when you're taking a shower" I presume you're talking about turning the shower hot/cold knob(s) and not the temp thermostat on the water heater itself.
If so, when it starts to run colder, turn the knob all the way to full hot. Is the water then very hot? If so, the water heater is working fine & doing its job, and the problem is likely to be in the shower faucet mixing valve itself. Sometimes a faulty one will expand the inner seals/cartridge as hot water flows thru it, and starts to (wrongly) restrict the hot water flow, thus causing the constant need to "turn the dial up a notch".
Oct 29, 2014 | Rheem Water Heaters
Hot water varies
I do not know how old this unit is or what model but many water heaters are not sophisticated enough to measure the temperature, but heat based on water flow and temperature rise. To start, tankless water heaters turn off every time you turn the hot water off. Lets use an example. You use the facilities, wash your hands then turned off the water and take a shower. You will bring the already heated water (from washing your hands) from the pipe up to the shower. Then the cold water that comes into the pipe from the reactivation of the water heater comes up the hot water pipe with warm then hot water just behind.
If this is not your problem, keep reading. Every unit I have been called to see were installed wrong. Check your installation manual to see if the problem with the system started with the contractor.
First, check the temperature of the water from the heater. If it is too hot and you are mixing too much cold water in, the unit will turn off because there is not enough water flow to keep it running.
Second, turn off the valve at the water heater and turn on the hot water at a faucet. If the water does not stop running, there is a "plumbing cross over" usually caused by a failing pressure balance valve in a shower.
Third, if the unit has not been serviced, go to bosch-climate.us to find a tankless water heating professional in your area. Totally Tankless LLC
Mar 14, 2014 | Bosch & Tankless LP Hot Water Heater
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
Keeps going from boiling hot to cold
At a guess either the shower head has become clogged/calcified or the piping inside the shower has become so.
This means that water stays in the system too long, becomes over heated and the failsafe cut off activates.
Try cleaning or replacing the shower head.
Jan 30, 2012 | Neptune Home
Water temperature cools when using the shower
the hot water heater may have sludge built up in it. drain a few gallons from hot water tank and see if this makes a difference. you should drain a few gallons fom tank at least 2 times a year, to keep the sludge from building up. ( is the tank big enough for the job)
May 13, 2010 | Home
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Water is either hot or cold
yes, the valve should be close at the downward postion. and the water should be clod to hot from left to right.
open the handle and pull out the cartridge.
make sure the valve body is installed right side up.
if it is, insert the cartridge with the lock pin on top.
reinstall the handle.
Jan 27, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Aquatronics AMS602WR Coaxial Car Speaker Logo
354 people viewed this question
Top Aquatronics Car Audio & Video Experts
xxxxxx xxx
Are you an Aquatronics Car Audio and Video Expert? Answer questions, earn points and help others
