Question about Lexmark T642 Laser Printer
Wiper blade Do you know where the wiper blade is located on the T642 Lexmark printer?
  • mac3 Jan 22, 2008
    Thank you. The printer just said wiper blade but it was the fuser. And I did find it on top of the printer.
  • Anonymous Feb 20, 2008
    where is the fuse wiper on the t642 printer?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
When you say wiper blade, do you mean the one in the cartridge? There's also a cleaning wand in the top of the fuser.
Posted on Jan 22, 2008
I tried to replace the fuser wand, but some of the tabs broke off and now it won't stay.
You might need to replace the Fuser Wiper Cover Assembly. The part number for the said part is 40X0001. Please contact any Lexmark Authorized Service Provider or contact our Technical Support Hotline.
Nov 07, 2012 | Lexmark T642 Laser Printer
My 1990 Suburban needs new wipers, I bought the blades, however I dont know how to remove the old ones because it seems to have a different set up. you cant find just blades anymore it comes with the...
The 1990 Chevrolet Suburban has the most common hook-end wiper arms. Locate and press the tab or button where the wiper blade is inserted into the hook of the wiper arm and pull wiper blade out of hook. You may have to rotate and flex the blade to make enough clearance for the hook to pass through.
1990 Chevrolet Suburban Wiper Blade Installation Videos (hook-end arms)
1990 Chevrolet Suburban Wiper Blade Size Options w/Correct Lengths & Attachments
Sep 11, 2011 | 1990 GMC Suburban
How do i remove the windshield wiper blade
The 1998 Dodge Grand Caravan has the most common hook-end wiper arms. See related links below for installation videos. Also, purchase the replacement blades first and there will be additional instructions/illustrations on the replacement packages. Locate and press the tab or button where the wiper blade is inserted into the hook of the wiper arm and pull wiper blade out of hook. You may have to rotate and flex the blade to make enough clearance for the hook to pass through.
1998 Dodge Grand Caravan Wiper Blade Installation Videos (hook front, hook rear)
1998 Dodge Grand Caravan Wiper Blade Size Options w/Correct Lengths & Attachments
Sep 09, 2011 | 1998 Dodge Grand Caravan
I need to change wiper blades on 2006 trailblazer. i can't get the wipers off.
The 2006 Chevrolet Trailblazer has the most common hook-end wiper arms. Purchase the replacement blades first and there will be additional instructions/illustrations on the replacement packages. Locate and press the tab or button where the wiper blade is inserted into the hook of the wiper arm and pull wiper blade out of hook. You may have to rotate and flex the blade to make enough clearance for the hook to pass through.
2006 Chevy Trailblazer Wiper Blade Installation Videos (hook end arms)
2006 Chevrolet Trailblazer Wiper Blade Size Options w/Correct Lengths & Attachments
Aug 16, 2011 | 2006 Chevrolet Trailblazer Ext
Error 04,024,04:2667?
Wiper Alignment Fault
Wiper Blade Misalignment Errors
Printhead Wiper Blade misaligned
Test the Wiper alignment.
Run the Service Diagnostics Check Wiper Alignment test.
Aug 02, 2011 | Xerox Phaser 8560MFP Laser Printer
How do I know when to use the fuser wiper cavity cover or the oil fuser wiper or the wax fuser wiper on my Lexmark T642?
The T642 is a monochrome printer and as such does not have an Oil wiper. The only wiper that should be needed with this printer is the hard plastic one that ships with the printer. These wipers are permanent and are only replaced when you install a new fuser. Oil wipers are usually only used with color laser printers.
Apr 01, 2011 | Office Equipment & Supplies
08,007.41:8472 It's a phaser 8400 i have no idea what to do..What could it be?
Your print head wiper blade is not moving properly.
The clutch that moves the wiper may be failing.
That blade is located between the drum and print head.
Printhead Wiper Alignment: Rotate the left and right idler gears until the Wiper is all the way to the bottom and the gears cannot be rotated further. Rotating the left and right gears together ensures that the wiper stays parallel and does not pop out of the belts. Now rotate the left idler gear a couple of teeth to raise the left side of the wiper to the top. Make sure that the left side of the wiper is a bit higher than the right side. Might have to try this procedure a couple of times, a couple of teeth at a time, to properly align the wiper.
Feb 08, 2010 | Xerox Phaser 8400 Laser Printer
I cant figure out how to change my windshield wiper blades on 2001 ford ranger
How to Replace Wiper Blades Guide (Typical):
Potential tools needed to replace wiper blades:
  • Flat blade screwdriver (small)
  • Small nosed pliers
  • Latex or vinyl gloves
  • Safety goggles
To replace wiper blades theactual action of replacing the blade is no big deal, it's the locationof the blade down below the hood that can make it difficult though.Sometimes it helps to open the hood to gain access to the wiper blades.Other times it is helpful if the wiper blade is somewhere in the motionline of wiper action. The trick is to get the wiper to stop somewherein the wiper arc. Turn the wipers to the on position and allow thewipers to start, and then shut the key off when the wiper has arrivedin a desirable position on the windshield. To replace your wiper bladesplease follow the step by step instruction below. Also, watch the How to replace wiper blades video below to gain additional information. The method in which the wiper blades are attached will vary slightly.
  • Step 1: With the hood closed, turn the wiperson, when the wipers are in the middle of their arc turn the key to theoff position. (Note: if this can't be done because of wiper conditionand you want to avoid scratching the windshield please open your hoodto gain access)
  • Step 2: Locate the mounting clips at the top pivot on the wiper blade
  • Step 3: Release the clip and remove the wiper arm
  • Step 4: Match the size of the old blade against the new blade to ensure proper fit and operation
  • Step 5: Reinstall the new wiper blade and recheck wiper operation
Common Problems:
  • Make sure the wiper blades are the same size as the original blades.
  • When replacing wiper blades not getting the blade onthe mounting pin completely allowing the wiper arm to become dislodgedand possibly causing damage to the windshield.
  • Using wiper blades after the blade has failed permanently damaging the windshield by craving scratches in the wiper arc.
  • Wiper blade can create a chattering noise when theblade is not properly balanced allowing the blade to "flop" back andforth as the wiper direction changes.
I hope help you with this (remember rated this help) Good luck.
Sep 16, 2009 | 2001 Ford Ranger Regular Cab
How do I remove front wiper blades to replace with new ones on my 2006 nissan quest
How to Replace Wiper Blades Guide:
  • Safety goggles
To replace wiper blades the actual action of replacing the blade is no big deal, it's the location of the blade down below the hood that can make it difficult though. Sometimes it helps to open the hood to gain access to the wiper blades. Other times it is helpful if the wiper blade is somewhere in the motion line of wiper action. The trick is to get the wiper to stop somewhere in the wiper arc. Turn the wipers to the on position and allow the wipers to start, and then shut the key off when the wiper has arrived in a desirable position on the windshield. To replace your wiper blades please follow the step by step instruction below. Also, watch the How to replace wiper blades video below to gain additional information. The method in which the wiper blades are attached will vary slightly.
  • Step 1: With the hood closed, turn the wipers on, when the wipers are in the middle of their arc turn the key to the off position. (Note: if this can't be done because of wiper condition and you want to avoid scratching the windshield please open your hood to gain access)
Common Problems:
  • When replacing wiper blades not getting the blade on the mounting pin completely allowing the wiper arm to become dislodged and possibly causing damage to the windshield.
  • Wiper blade can create a chattering noise when the blade is not properly balanced allowing the blade to "flop" back and forth as the wiper direction changes.
Sep 14, 2009 | 2006 Nissan Quest
Lexmark T642 Laser Printer Logo
602 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
