Question about HP LaserJet 1300 Printer
All in one h.p. printer 1300 reads out of paper even when full !
    President:
  • HP Master
  • 990 Answers
Hello sir; Do you push paper tray all the way in until you hear the "click" noise, also check the paper senser that underneath the machine above the tray.
Posted on Sep 28, 2009
After initializing blink that tray have no paper but paper in the tray
Pull out the tray, restart the printer, put the tray back and try, it should read try normally. Regards, Mike
Jan 14, 2016 | HP LaserJet 1300 Printer
Hi I've got an epson stylus dx4400 printer. The printer is a little strange because two of the ink cartridges are reading full, even though one of them is completley empty and the other is about a quater...
There is no sensor that reads actual quantity of the ink in the printer. The measurements are based on calculations how many pages are printed and what has been printed after last ink cartridge replacement. Probably the printer has been tricked that there is a new ink cartridge, but there is the old one.
Often a small object can fall in the paper tray and go down the paper path, preventig paper from picking up and moving. Rotate the printer with the front side up and try with thin and long flat skrewdriver to rise the thin long rollers that hold the paper to the feed roller, one after another. These rollers are held there by springs. If someting is stuck behind them, it should fall down. I've found there coins, pensils, rullers, paper-clips and so on.
Jun 15, 2010 | Office Equipment & Supplies
Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Apr 03, 2010 | HP LaserJet 1300 Printer
Canon iP 1300 keeps coming up with Paper Jam
this problem may be due to many reason.
first due to moisture in paper. try some good one and rey paper.
second due to dirty paper feed roller problem. clean the roller with moist cotton using cleaning liquid such as spirit, petrol or nail polish remover.
and last may be due to mis allignment of paper feeder assembly contact any printer specialist.
Aug 21, 2009 | Canon PIXMA iP1300 Printer
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
Frequent paper jams.
hi im josh in cebu phils. may i help you? friend if the problem still occurs even though it was already repaired. there is a hardware problem involve possible the paper feeder roller.try to remove it and clean it first so that you can economized the cost.but if it still occur you need to change that already so that you can use the printer. good luck friend.
Feb 27, 2009 | HP LaserJet 1300 Printer
HP psc 1300 printer
I had to turn off my computer, unplug the printer power cord and computer cord. I restarted the computer and pluged in both cords to the printer and it worked.
Oct 07, 2008 | Office Equipment & Supplies
HP Laserjet 1300 will not feed paper
You may need a new roller, or pad.
Aug 11, 2008 | HP LaserJet 1300 Printer
Printer problem
Hey there.
1-st of all please tell us what printer model do you have and what kind of paper are you using.
Mar 19, 2008 | Office Equipment & Supplies
HP LaserJet 1300 Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
