Question about Dell 1600n All-In-One Laser Printer
Can't get MAC software to print to a Dell 1600n printer
I have a Dell 1600n black and white printer I bought in 2005. I use it to print with a PC. The drivers are loaded on the PC but the installation was done as a network printer so the PC can print using the wireless modem we have at home. We have a second computer that is a MAC (OS 9 I believe) and we can't figure out how to get it to print to the Dell. Dell customer support said they don't make print drivers for that particular model for the MAC but I am hoping there is another way to do it.
3 Suggested Answers
SOURCE: Driver for mac OS for Dell 1600n
If you install the Xerox1600n it should work for you. That is what we had to do.
Posted on Apr 28, 2008
the Dell 1600n is indeed a re-branded Xerox PE120. I did a search on that model and "OS X" and found the appropriate driver on the Xerox website. Loaded it and it works like a charm.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=PE120_PE120I&Xlang=en_US&Xcntry=USA
Posted on May 08, 2008
How do I find the MAC address to mt Dell 1600N laser printer ??
Press the Menu button on the front panel of your printer and scroll to Printer Setup .. under it you will find print configuration page .. once you select that and hit enter/ok it will print a page and you can find the MAC address on it
Jan 02, 2011 | Office Equipment & Supplies
Have got new pc driver for Dell 1600n needs to be installed
Here is the link from Dell Official Support for Drivers download for Dell 1600n
Select Operating System and get the drivers and software.
Good Luck!
Appreciate generously if the solution could have been of any help!
CreativeTECH
Dec 16, 2010 | Dell 1600n All-In-One Laser Printer
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Jul 24, 2009 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n to be used on an imac
Hello! Unfortunately, Dell printers mainly supply Windows drivers on their website. To print to this printer, your new iMac will probably pull a generic driver to use with the printer. It should still work no problem, as you're saying, however you won't be able to use the software that's available on the PC. The downloads available for your Dell printer are here:
Dell 1600n Printer Downloads
You can tell by clicking that link and looking under Operating System that only Windows operating systems are available, as well as the software shown below, which is only made for Windows based systems. As for the PaperPort software, that program is made by a company called Nuance. When you purchased your printer, you most likely received a trial or full OEM version from Dell along with your new printer as a software bundle deal. From what I can see, the software is only Windows based. Sorry!
Below is the link to a free viewer that can still read your PaperPort files:
PaperPort Viewer for PC and Mac OS [Free]
Mar 16, 2009 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
My dell 1600n will not print recieved faxes
ok..one at a time..if you want, repost these separately to me, if they are still current.
Jun 05, 2008 | Dell 1600n All-In-One Laser Printer
Feb 24, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Non Dell cartridge
I have bought a cartridge from a third party and my printer says non dell cartridge and I can't get it to print.
What do I need to do to get the 1600n accept this cartridge?
Sep 11, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
81 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
