Question about HP PSC 1210 All-In-One InkJet Printer
The printer rolls, but does not pick up the paper to print.
If you take it apart you'll probable see that the gear for the roller is slipping on the shaft, you can try to push it in, further on to the splines of the shaft, but I don't know how long it will last.Be careful of the clear sticker on the gear, it has marks and is used to tell position of the gear,by reading the marks on the disk on the IR opto that is on the circuit board.
Posted on Sep 29, 2009
  • pjake Sep 29, 2009
    I also see alot of post about the printer printing half a page then stopping and and then it feeds the rest of the way on a print job, I would also suspect a slipping end gear, because of the opto encoder I described above, if it was slipping the paper would stop as the shaft isn't engaged on the gear anymore.
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
Tracing paper not picking
If you mean Vellum paper, make sure that your paper type is set from your server/computer to the printer. Remember, Stock rolled paper has different physical characteristics than Vellum. Also this will aid on the paper sensor to note what type of paper you are printing on
Jun 02, 2014 | HP DesignJet 430 InkJet Printer
Factory resetting
go to the printer properties and check the paper size you are using. It should be set to a4 and it will recognise that size paper . make it a default setting.
Jun 20, 2013 | HP LaserJet 1020 Printer
Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Apr 27, 2010 | Samsung ML 2010 Laser Printer
Kodak easy share g600--paper doesn't get pick up
Try putting a taller stack of paper in the printer. As they get older, the wheels lose traction. Clean the wheels you can see with a damp Q-tip.
May 01, 2009 | Office Equipment & Supplies
Re HP Laserjet 4P after inserting envelope to print, upon giving PRINT command, printer will not print and indicates PAPER JAM. However, there is no real paper jam. No problem printing regular 8 1/2 x 11...
Most likely a bad pick up roller these machines will give a jam error if the paper or envelope is not picked up. Try cleaning the roll for the tray you are having the trouble with if the condition improves you have found the problem.
Hope this helps
Apr 19, 2009 | HP LaserJet 4 plus Printer
Paper picking problem
try to clean the paper pick-up using soft cloth and water clean the rolls serval times it will solve ur problem
Nov 28, 2007 | HP DesignJet 110 Plus InkJet Printer
TRACTION PROBLEM
The cam that keep the pressure between the roller pick up and the lower feed is the solution
Oct 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
100 people viewed this question
Seeker5211
Seeker5211
