Question about Ryobi P501 18v Circular Saw Only
Ryobi 18v circular saw owners manual - blade is loose!
Ryobi 18v circular saw operators manual.
blade is loose and I don't know how to tighten it.
  • juliakrodger Sep 29, 2009
    will the blade still wobble a bit after doing that? I pushed the button, inserted wrench then turned but the bolt moves slightly but never STOPS moving, and the blade still wobbles on the shaft.
  • Anonymous Mar 30, 2014
    How do I tighten new blade? Every one stumped so far.
  • 5,603 Answers
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Posted on Sep 28, 2009
Testimonial: "Thanks; that's the advice I got when I tracked down the number to call Ryobi. However, it doesn't seem to be working. Now sure what is wrong :("
Bought the new ryobi 7 1/4 inch miter saw. Factory installed blade stops but spindle doesn't. There is an inner ******/washer, then the blade, then an outer ****** and then the bolt. Why is blade stil
The shoulders on the washers have to be properly aligned with the hole in the saw blade so the nut can tighten properly. Are the washers turned the right way? Try flipping one or both the opposite direction.
Sep 13, 2014 | Saws
Saw blade improperly installed, both washers on outside of blade and can not unsrew
does this tool have a spindle lock? what I would try if not is putting the blade on a block of wood and using the drill and a socket adapter to loosen bolt, if appears from the picture that this might be a left hand bolt, this should take care of your problem. Let me know if you need more assistance and if you do give me the saw model number so I can find a schematic.
Feb 27, 2011 | Ryobi 3-piece 18V Drill / Circular Saw /...
My Ryobi P501 cordless saw is noisy, sounds like it may need bearings or gears.Are there any common problems with these units?
No but where did you buy it its a small saw mine works fine but its for limited use. You can't use it to cut frameing lumber but its handy.What have you done with it when was the last time you changed the blade ? Idon't know i have 5 or 6 differant skill saws differant blades differant uses its olny disigned to do so much
Dec 14, 2010 | Ryobi P501 18v Circular Saw Only
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
How do I disengage the drive shafts to tighten a
should be a black button between the handle and the guard. Spin the blade until it depresses all the way down and you should be able to loosen the blade.
Dec 05, 2009 | Ryobi P501 18v Circular Saw Only
How do I install the blade
you need to pull back the lower guard (remove battery first) and then start the blade at a slight angle until it goes into upper guard and then put on the spindle and reinstall the flange and blade bolt and tighten bolt till snug. You might try Ryobitools.com for a users manual or call them direct at 1-800-525-2579 and have them email a manual to you.
Sep 27, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
How do i change the circular saw blade on my saw? because i cant get the blade out to swap it as its blunt and the blade is now blunt
After removing the blade bolt and the outer flange you will need to fully retract the lower guard (remove battery) and sometimes wiggle the blade but it will come out.
Aug 29, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Ryobi P501 18v Circular Saw Only Logo
990 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
