Maytag MSD2756G Side by Side Refrigerator Logo
Posted on Sep 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It appears as though it is not defrosting. Is is set as timer. If I unplug it will work fine for 2 or 3 days then temp starts rising and inside of freezer starts to glaze over with ice. Where is the control for defrosting?
  • mmck8039 Sep 29, 2009
    Thanks.. Now, I am sure I could of fixed it. However, the problem has been OBEd. I just found an extended warranty I don't remember buying 3 years ago. Still good for another year. Let the pros do it. Thanks Again...
Anonymous
Level 3:
Brigadier General:
  • Master 3,513 Answers
  • Posted on Sep 28, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
3513
Questions
0
Helped
867857
Points
10095
Thanks for contacting Fixya.
Yes, the most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
I am sure this information would assist you.
Thanks
Ffbm 920w won't cool
It appears that your auto defrosting system (if you have one) is not working. So your evaporator coil is frozen up - all that ice serves as an insulator and not enough cold air is getting down into frig section. Until you replace either the freezer defrost element or the defrost timer all you need to do is unplug for a few hours till it fully defrosts then plug back in - will work fine for a few days at normal internal temps till the ice builds up again.
If your timer and defrost element are both working properly, THEN, you might want to check if you have enough refrigerant in the system - you may have a leak.
My GE side by side door seals are hot. Last week, I vaccumed underneath and cleaned ice that had accumulated inside the bottom of the freezer. The drain hold was clogged. I poured 1/2 cup of warm soapy...
It sounds like the defrost circuit is on. Usually this circuit comes on every 8 hours or so and runs for about 20 minutes - or until a thermal sensor on (or near) the actual freezer coil rises to about 50 degrees F - whichever happens first.
The defrost circuit on some fridges not only activate the defrost heater in the freezer coil compartment - but one or more small heaters in the fridge cabinet door jambs where moisture is likely to form on humid days. Some fridges have a selector switches that enable or disable these "moisture control" heater(s). In any case, the defrost should not be on all the time.
Rising temperature in the freezer / fresh food compartment can be the result of a dirty condenser coil. Depending on the fridge, the condenser coil may be viewed and cleaned (vacuumed) from lower front (after removing the toe space bezel) or from the rear - behind an easily removed cover - often made of a thick cardboard / fiber material. You should only vacuum and clean the coils, fan blades, etc. when the fridge unplugged.
The fans that blow cold air from the freezer into the fresh food compartment may no longer be spinning - due to disconnected wires, motor failure or physical obstruction.
The defrost circuit timer may have become stuck in the defrost mode. Even though the thermal sensor will stop the heat once it reaches 50 degrees - if the timer is stuck - it will never enable the compressor. Defrost related repairs are cheap compared to a compressor failure.
Lastly, the compressor or refrigerant lines may have failed. This can be a costly fix. I hope this helps and good luck!
4helpful
2answers
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Refigerator temp is rising Lower freezer compartment seems to be fine
Check rear wall of freezer by feel for frost. Frost indicates likely problem in the defrost system. Defrost heater (in freezer), defrost thermostat (in freezer) or 1 of Defrost timer or Defrost control (Circuit board) generally located in Refrigerator compartment but may be inside rear of outer case.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model and brand is always helpful when requesting information.
Model ED20PKXAN01 side by side. Defrost timer
The timer could be set for accumulative instead of continuous . The one wire on the timer , set on the wrong terminal .
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 • Freezers
No air circulating the no frost refrigerator. Electrolux 2 door
It sounds like a defrost problem. Maybe the defrost timer is not advancing or it could be the heater in the freezer. Find the defrost timer and advance it to defrost. You will hear a click and the compressor should turn off. Then wait about a minute, unplug the cord slow. You should see a spark when you unplug. If you do then the heater is working. Change the defrost timer. If no spark then it could be the heater or terminator.
My reach-in frig. building ice around the coil & then the temp. starts rising
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
