Flashing red clock sign
After turning dvd off at the mains and then switching it back on I have not been able to access the dvd in any way. It appears to have locked itself out, and only a blank clock and a flashing red clock are visible. I have tried the solutions in the manual but to no avail. Please help???
  • 2 more comments
  • Yelsel Dec 18, 2007
    No. Cannot access at all. Machine was working perferctly until I turned it off at the mains.
    Ok will do that and let you know. Thanks.
    Turned it back on but same problem still there. Any other suggestions?
    After turning dvd off at mains and then turning it back on I am left with a flashing red clock on dvd screen (model JVC DR-MH300SEK/BEK)Can not access machine by any means. Any suggestions anyone?
    President:
  • 1,944 Answers
If the solutions in the manual didn't solve anything...I am afraid that you will need to get it serviced. Sorry to be the bearer of bad news...
Posted on Dec 18, 2007
    Genius:
  • 1,153 Answers
Sounds like timer problems. Can u access menu and go to timer and turn off?
  • Lashawn Robinson Dec 18, 2007
    Well can you unplug and leave for at least 15 min and try again?
    Is there a Disc in unit?
When turning a knob on my Siemens cooktop, a blinking "0" appears, and a red lock sign shows.I pressed the lock sign for min 5 sec but it stays on. How doi turn the lock off in order to use the stove?
Hi,maybe if you have not tried it already,maybe switch it off at the mains and swich it back on it may reset its self,hope it works for you.
Aug 16, 2016 | Siemens Cooktops
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
DMR-EX75B - tuning gone with clock
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Mar 04, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
The players red and green light keeps flashing and wont come on
THIS CAN BE SOLVED BY CHANGING THE MAIN POWER SUPPLY BOARD OF YOUR DVD PLAYERS. The main problem should be the Main Capacitor in the circuit. The safer side is to change the whole board.
Apr 23, 2009 | Televison & Video
Panasonic DMR-EX85 fault code U99
This is the solution from the on line owners manual for you product at www. panasonic.com. U99 ≥The unit fails to operate properly. Press [POWER í/I] on the main unit to switch the unit to
standby. Now press [POWER í/I] on the main unit again to turn the unit on. I hope this helps you with your problem.
Jan 30, 2009 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
