Question about Da Kine Car Rack Pad Set Surfboard Bag Thule Dakine Suv Kayak
Can you confirm how the straps are correctly to be used to hold the surfboard in place?
    Problem Solver:
  • 10 Answers
Place pads around your cross bars, thread straps over the board and under the bar on the far side and then over the board with the buckle end on top of the near side of the board. Then wrap the other end under the bar and 1 time around on the near side, thread through the buckle and pull tight....repeat.
Posted on Nov 14, 2009
How do i remove the battery of a 2008 Chrysler Sebring to put a new one
First thing get the code to the radio so that you can turn the radio back on . Turn everything off . Disconnect the earth lead off then the positive lead. Remove the battery hold down strap /clamp and lift battery out. Ensure that the replacement battery has the same poles in the same places or the leads may not fit correctly. Place the battery in position and fit the hold down clamp/strap. Fit positive lead after ensuring that the terminal is shiny clean inside. Fit earth lead after cleaning the terminal . Tighten clamps securely. Turn igniting on and wait a few minutes for the CPU to reprogram. Start engine and wait for the ECM to sort out any losses from the battery removal.. If there are lights tha stay on it may be necessary to have a code reader used to reset the CPU
Oct 24, 2013 | 2008 Chrysler Sebring
REPLACING FUEL TANK STRAPS
I know it can be a bear if the bolts and pins are rusted. Unless the new straps are OEM, some after market straps don't fit quite as well and you need Godzilla strength to manover them into place to get them pinned and bolted back up.
You shouldn't have to drop the tank as long as you do the straps one at a time. Get a floor jack, transmission jack or even a motorcycle jack and place wood under the gas tank and do one strap at a time. I used a second jack to help push the strap in place so I could push it into place on a 97 Dakota. Good luck and sometimes it goes smooth but, some times it makes a preacher say things they wouldn't say in church. :)
Dec 28, 2011 | 1996 Dodge Dakota
Where is the in line fuel filter
Fuel filter for the 98 Voyager is located on top of the gas tank. Jack the vehicle up and support it with blocks. If your tank is more than 1/4 full, support the tank with an appropriate jack and remove the two bolts holding the straps in place. Lower the tank enough to gain access to the filter. A new filter comes with the correct hoses and quick connect couplers so it's dead easy to replace. If I recall correctly, the filter is held in place by one or two bolts and a strap. Before removing any fuel lines or seals, remember to release the fuel pressure in the lines with an appropriate hose/container via the valve on the fuel rail on top of the engine.
Aug 04, 2011 | 1998 Dodge Caravan
I need instructions for the genki house baby carrier and for the bubba moe baby sling
Here are Genkihouse Sling instructions - I tried to attach scanned copies of the instructions, however it exceeded the file size limit:
For front use
  1. Hold your baby close to your chest
  2. Still holding baby close to your chest, grab sling and place over baby - Genkihouse logo facing away from you, arrange baby's legs through leg openings. Alternatively, you can lay the sling on a change table with logo facing down, lie baby on top and put legs through leg holes then lift the baby and the sling onto your chest.
  3. Still holding baby close to you, place sling straps over your shoulders.
  4. Reach behind with one arm (still holding baby with the other) and firmly take the strap from behind opposite shoulder. Your other arm still holds the baby and sling.
  5. Thread the strap through D ring with one hand whilst your other hand still holds the baby.
  6. Simply 'hook' the strap through the D ring with your index finger.
  7. Do not change hands at this stage.
  8. Tension strap backwards - away from your back and don't let go.
  9. Feel the baby's weight now firmly supported by the sling at your waistline.
  10. As you continue to hold the same strap reach behind with the other hand and thread the second strap through its D-ring. The straps should criss cross over your back.
  11. Bring straps together, adjust tension to suit and tie a secure knot in the middle of your back.
  12. Check the position of the baby - you should be able to kiss his/her head.
  13. Baby can also face outwards when he/she gets older.
Jun 15, 2011 | Baby Gear
How do you drop the fuel tank on a 2002 Dodge Grand Caravan to replace the fuel filter?
On most these, there are two tank straps which are bolted to the undercarriage which hold the tank in position. It's easier to do with the tank empty or very close to empty. Place something under it to support it such as a jack and remove the bolts holding the tank straps in place, that should let the tank drop out, then you can remove the connections for fuel and electrical.
Jan 25, 2011 | Dodge Grand Caravan Cars & Trucks
Need to take gas tank off does it just bolt to frame
Some vehicles used straps that bolted to the frame. Check to see if there are straps holding up the fuel tank. If so, usually one side of the strap is bolted on and the other sits inside a pivot point. If one side is bolted, just remove the bolts from the end of strap and the strap will swing out of place.
Jun 23, 2010 | 1990 Toyota Pickup
I have this Schwinn Trailblazer Bike Trailer and Stroller. It is wonderful. However there is a strap that is bolted on to the main frame and to the spring end that connects to the bike hitch. My husband is...
This particular strap is a safety backup strap. This strap is just for in case that the first one securing the trailer to the bike breaks so it will still stay connected to your bike.
May 20, 2010 | Schwinn Trailblazer Bike Trailer
Door will not hold open ,and comes back at you, what is the name of the part ?
The door strap, that piece of flat metal that comes in and out of the fender when you open the door has a couple of notches to hold it in place. Those notches 1) wore out and the strap is smooth 2) the strap is lubricated and doesnt have enough friction to hold in place 3) the strap got loose, is out of alignment and the notches are not catching
Nov 17, 2009 | 2000 Hyundai Elantra
Washing Carseat Fabric
You may have solved this problem already, but I had a similiar situation. If you can remove the round hard plastic fasteners that the straps pass through, it really is not too difficult to take the pad off. They are just clips that push against the hard plastic back of the seat to hold the straps in place. To remove them, I just took a flat head screw driver and placed it against the long side of the fastener and pushed up and toward the center of the fastener. I did this for both sides of the fastener and it popped right out. The straps then just unhook from the back and thread through to the front. Make sure to note how the straps are placed so that they can be replaced correctly. The pad washed up very nicely for me. I used warm water and regular detergent. I let it dry in the sun. Hope that this helps.
Jun 10, 2009 | Eddie Bauer 31447 Booster Car Seat - Sage
Thibohr
it should be just the two straps that are holding it in place you may need to wiggle it a bit and did you take the flller hose lose? you know where you put the gas in there should be a clamp holding it in place.it should drop down with the two straps loosened
Aug 22, 2008 | 1983 Honda Accord
Da Kine Car Rack Pad Set Surfboard Bag Thule Dakine Suv Kayak Logo
89 people viewed this question
Top Da Kine Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Da Kine Boating Expert? Answer questions, earn points and help others
