Question about Vehicle Parts & Accessories
How do i bypass a factory disarm on a 99 doge grand caravan ?
  • 344 Answers
You have to ground the white/green wire through a 650 ohm resistor, left connector bottom of fuse panel
Posted on Sep 29, 2009
My 1996 doge grand caravan in blowing cooling fan fuse why
The cooling fan fuse may be blowing because the fan motor has gone bad. Check with the fuse out, and motor off grab the fan and wiggle it, if it wiggles this is your problem, and solution is to replace fan or complete assembly. GOOD LUCK.
Jun 17, 2011 | 1996 Dodge Grand Caravan
2001 Doge Grand Caravan has had the radiator replaced. It is blowing a lot of white smoke out of the tail pipe. It is not leaking water.
your coolant is getting into the combustion chamber and then being pumped out the exhaust. you need to get the fault corrected, bad gasket or crack.
Feb 15, 2011 | 2001 Dodge Grand Caravan
SECURITY SYSTEM KEEPS SHUTTING THE CAR OFF. RESETTING THE SYSTEM DOESN'T HELP. HOW DO I BYPASS THE SECURITY SYSTEM
If you are handy with vehicle electrical, you can apply ground to the factory disarm wire, to permanently disarm the factory security. It's location and color;
Factory Disarm Purple/Yellow (-) in Driver's Kick Panel---Black Connector
Feb 14, 2011 | 1995 Jeep Grand Cherokee
Which fuses can I remove to disarm 1994 jeep grand cherokee. Jeep is stuck in security mode and will not start. I bought it used, so no keyless entry. Manually unlocking/locking driver door, passenger...
I don't know about a dedicated fuse but you can try disconnecting the battery for a few minutes then, with the battery still disconnected, turn the ignition key to on, then reconnect the battery. This has been a known way to also disarm the factory security.
If that doesn't work, and if you are handy with vehicle electrical, you can ground the factory disarm wire, to permanently disarm the factory security. It's location and color;
Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector
Feb 06, 2011 | 1994 Jeep Grand Cherokee
Where is the alternator on a 99 doge caravan
If it has a 3.3 or 3.8 it is located on the passenger side on the top towards the back.
Sep 22, 2010 | 1999 Dodge Caravan
Yellow light
OIL pressure?
If that's it --
Have it looked into ASAP!
Jan 04, 2010 | 2008 Dodge Grand Caravan
Need bypass factory alarm in 99 dodge
well thats an interesting idea but by bypassing the alarm your car will not usualy start it is a safety feature that is built in to all chrysler autos it will disable the starter coil door locks windows and half the electrical systm as a safety feature and anti theft feature
Dec 30, 2009 | 1998 Dodge Caravan
Cruise and horn doesnt work 2002 dodge grand caravan
In most cases this problem is caused by the rotating ribbon circuit contact under the steering wheel having a broken filament, the part is known as a clock spring contact, u will need to properly disarm the airbag and remove the steering wheel to access the part. WARNING: Failure to follow factory Airbag disarming protocol can result in an unexpected Airbag deployment and possible serious personnel injury or death.
Jun 19, 2009 | 2002 Dodge Grand Caravan
2005 g caravan
this is telling u that a fault has been detected in the airbag circuit by the airbag diagnostic monitor module (system is disabled when light is on), the most common cause is the rotating ribbon contact called the clock-spring contact has a break in it's circuit to the airbag on the steering wheel. To replace this you must disarm the airbag system and remove the steering wheel. Follow factory protocol for disarming airbag or serious injury can result from unwanted deployment of the airbag
Apr 02, 2009 | 2005 Dodge Grand Caravan
Vehicle Parts & Accessories Logo
63 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
