Question about LG Washing Machines
Dryer is not drying and I think blowing cold air.
  • LG Master
  • 19,396 Answers
Solution depends on the dryer model.
On many dryer of both kinds (electric and gas) there is a thermal fuse mounted to the exhaust duct . Test the fuse using multimeter to read continuity. If it has blown replace it.
On electric dryer.
Test heating element. Element is tested cutting wiring to element contact, and reading Ohms with multimeter set to Rx1. If it has infinite ohm, then element is faulty.
After heating element test the high limit thermostat. thermostat must read low impedance at room temperature, and will have no continuity at limit temperature.
If both parts are OK, the technician will read voltages on wiring harness from electronic control. For safety reasons it is better if the user does only tests with power not connected.
If this is a gas dryer instead:
Check if the ignitor has spark, if it does , then the ignitor must be replaced, after testing if there is power getting to ignitor. Valve is usually regulated by a coil mounted on top of valve assembly, test it or replace the valve assembly.
Posted on Sep 28, 2009
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying).
So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty;
Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct.
24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
Jun 16, 2014 | AEG T58840 Dryer Electric
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
My dryer is only blowing cold air and not drying
Probably either the igniter or the gas valve.  They are both located in the front on the lower right.  You will need to remove the top of the machine and the face to get to them.  Take the switch out of the door, tape it so it thinks the dryer is shut and plug it back in.  The igniter needs to let a certain amount of current through to open the gas valve.  The easiest way to check it is to run the dryer and see how bright it glows. If it's not almost white replace it.  If it doesn't glow at all check to see if it is getting power.  If it isn't you will need to get someone to look at the control board.  If you recently moved make sure your gas pressure going to the dryer is correct.  If the pressure is too high it will keep the valve from opening.
Dec 04, 2009 | LG DLG0452W Gas Dryer
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Dryer
Disconnect the vent from the back of the dryer and dry a load unvented too make sure you don't have lint built up in the vent line causing an air flow restriction.
Jul 30, 2008 | Kenmore Dryers
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
