Question about Sony PlayStation Portable (PSP) Console
Will not turn on it was not dammge in any way.
  • 344 Answers
Probably a bad battery, mine did the same thing, and I replaced the battery and all was well
Posted on Sep 29, 2009
The hazard back lights wont quit blinking when car is running even when i pull the fuse on a 2002 buick regal
What fuse are you pulling ?
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Feb 11, 2017 | Buick Cars & Trucks
Looking for help diagnosing circuit board on sub12 venue series. It powers up red led, and goes green when sensing input. Power supply and speaker checks out good. Any suggestions? Thank You
the change from red to green is simply the auto sense of the input signal happening . have you ck the simple things first , like the volume control (im sure YOu didn't touch it , but maybe someone else did) , did the input jack sustain some internal dammge that might not be seen from the outside ? how did you ck the speaker ? did you sub it out with another known working one (doesn't have to be same size to try it) ???
Jan 21, 2016 | JBL Venue SUB10 Subwoofer
I have 350psi 900cfm ingersoll rand compressor on drilling rig after warm up when l press air pressure button to build up pressure it does not respond
well some common problems that compressors stay in "unload" are :
(1) a control is misadjusted ,its common on multi user machines to find something not quite right
(2) lube oil or cooling media is low , this is a safety measure that most machines have
(3) the unloading valve is dammged or part of the un load ck is damaged
Dec 26, 2015 | Ingersoll Rand Air Tools & Compressors
Why wont my dremel turn on??
1st ck to see that outlet has power on it by using a known good light (drop lights work great for this) next if tool is plugged into a foot pedal or speed control remove this and connect direct to outlet , activate switch on tool see if it runs
if not you most likely have a dammged brush on tool <this is very common i usually go thru two sets a year , brushes are available for dremels where ever dremel brand bits and tools are sold ck on back of package for your model number
if doing a lot of sanding or grinding allways make a habbit of blowing out air vents on tool body with a strong source of compressed air (canned air ok) this helps keep it going for years
Aug 19, 2014 | Dremel 400 Xpr Rotary Tool
My deck isn't engaging and I'm sure I screwed up the electrical. I disconnected the pto and it's not engaging now
do you think you dammged the cable or connector to pto clutch as it's electrical ?? if so you'll need to repair/replace this
May 18, 2014 | Garden
Acer keyboard
have you dammged the key ?
Jul 17, 2013 | Computers & Internet
If timing belt comes off and you try to start car but stop is there engine dammge mazda 626 1995
hi there it will probably will have done some damage to the valves (bent them) regards
Feb 02, 2010 | 2001 Nissan Quest
I have a acer travelmate 5320. everything on my screan has got bigger and i would like to make it smaller. pls help
Click the right mouse button on the desktop and then click on personalize or properties (depending on your operating system)
For vista click on display settings then choose a higher resolution.
On XP click on the far right tab then change the resolution.
Jan 08, 2010 | Acer Computers & Internet
Gateway 500x power short
your power supply may be dammged or set to the wrong voltave you can make sure it is the right one on the back of the power supply there should be a switch like button with a number
Oct 05, 2009 | Gateway 500XL PC Desktop
When i drive my 1994 talon it seems like it is not shifting
sounds like a torque converter issue as well as overall tranny problem leake could be a hose of could be a crack soudns like tranny is beyond repair and will be huge cost to nrepaire u may beable to save it if u have leak fix and flush tranny completely but i must warn u any vehicles more than 10 years old with more than 100 tho miles do not recomend a tranny flush because of sluge build up that may dammge gears
Feb 10, 2009 | 1994 Eagle Talon
Sony PlayStation Portable (PSP) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
