Nikon Coolpix 8800 Digital Camera Logo
Posted on Dec 18, 2007
System error 2
Every time I take a picture I get the SYSTEM ERROR 2. Please Help. Also I am triyng to take pictures of some jewels and I cant seen to get it to focus correctly (possible setting problem).
  • bryanscamera Dec 22, 2007
    after taking a pic system error 2 appears and camera blocks any use.
    It must be switched off to continue
A
Anonymous
The SYSTEM ERROR 2 problem that is occuring with your camera could be the memory card. Also try cleaning the connections
When i toke the picture and want to see picture it ok but while going to take another picture ,in desplay there is System error(zoom). after that the lence never goes in. i cant take picture any more and...
That is an issue that needs to be repaired. Here is the repair form to help http://www2.panasonic.com/webapp/wcs/stores/servlet/RequestCenter?storeId=15001&catalogId=11017
Cant go to picture mode, error on screen shoes
try to remove the battery first for a few minutes...then retry. This might help reset the system
2helpful
CF Card Error
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
2helpful
I cant get a picture to display after just replacing the lamp
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
Cant recieve picture messages
before receiving or sending picture messagers u must activate the MMS settings by requesting ur network provider only then u can send or receive picture msg
if u hav a signal problem nothing can be done
a small suggetion is in stores they sell a external antenna try getting it and fix it
tat helps in signal problem
Memory card error
Bet you have a bent flash card pin. Remove the card and look in the slot for a bent pin. If so, remain calm as you might be able to fix it. Remove the camera batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
1helpful
I cant send nor receive pictures
Hi Kim, Contact your provider and ask them to send you there WAP and MMS settings, usually when you recieve theese you switch off your phone, power it back up and YOU need to send a picture to activate the MMS settings with your provider. Good Luck!
Cant use picture project with my camera
Hello, if you are using I-link there can be the problem in the camcorder. This error can be pretty expensive for the repair. Please contact the nearest Authorized Sony Service for price estimate. If you need more info please advice.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
