Question about Sony Cyber-shot DSC-T300 Digital Camera
The calibration is off. How can I fix it? - Sony Cyber-shot DSC-T300 Digital Camera
I have a accugreen 1000. The wire for the settings has gone slack and I can't adjust the settings. It just stays open. How do I fix this.
You can try to calibrate the spreader, tightening the screw at the end of the control wire should fix the situation. If calibrating the spreader does not help please call us at 800-543-8873 for more assistance. To Calibrate the Accugreen 1000: 1. Adjust the micrometer setting to a 6. 2. Flip the spreader over. 3. Use your foot to squeeze the trigger against the handle. 4. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. 5. To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insect.
Jun 13, 2011 | RTO Accugreen 1000 Drop Spreader
How to fix screen calibration on the phone?
Go to Menu>Settings>Phone>Calibration
Note: it doesn't always calibrate on the first touch on each point. It might take you many tries to get it to move to the next point.
It is best to do this operation with a Q-tip, which resembles a finger to the Eternity's software more than a sharp point, but is also more accurate than a finger.
To test the calibration, dial *#0*# and press "9"
If this did not fix your problem, or you think you have a hardware issue
Feb 28, 2011 | Samsung Eternity Cell Phone
My touchscreen calibration is out of sync and it will not allow me to get to the menu to fix it
Hi have you tried taking the battery out wait a few minutes and put it back in and start the phone it should fetch the calibration screen up for you to calibrate if your digitizer is still working.
best of luck.
Dec 20, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My hp 3600n is stuck in calibration. how do i fix this?
I created a page on my blog where I outlined how I fixed this problem with my printer. I detailed the process and included some pictures http://www.mikekrauss.com/115/hp-3600n-constantly-calibrating-fix/
May 11, 2010 | HP LaserJet 3600n Printer
Auto rotate not working. g sensor calibration not
I have the similar problem on my touch HD. its vertical calibration bubble is not in the middle and pressing calibration is not fixing the problem. Auto rotate is also not working! Any one knows the solution??
Oct 25, 2009 | HTC Touch HD Smartphone
How to fix ink lines running vertically on sheet
The system needs to either be cleaned or calibrated. The print heads can be cleaned with rubbing alcohol and cotton swab. To calibrate, you may have to look in the manual for maintenance or calibration settings.
Jun 30, 2009 | HP 640 Inkjet Fax Machine
Top of form fault
Top of form fault - I assume you hit "Feed" button and still got the form fault... if so:
1. check paper sensor position, sometimes just 1/8" one way or the other will make a difference.
2. calibrate the printer to the stock you have loaded - calibration is EASY, just press and hold the feed button until the printer cycles 8-10 times. Let go, should say "Calibration Complete". Hit "Feed" again to see if your top of form fault is fixed.
Jun 10, 2009 | Datamax M-4208 Thermal Label Printer
Touch screen will not properly calibrate
Under settings, go to "system" and go to "touch calibration" and see if you can fix it there.
May 30, 2009 | Sylvania SMPK8854 Digital Media Player
40" LCD Samsung LN-T4061FI've noticed my blues are green.
there is no calibration for this, what kind of problem are you having?
Jan 10, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Sony Cyber-shot DSC-T300 Digital Camera Logo
26 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
