Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Can't get any water to flow through my bissell proheat rug shampooer
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tuitu
Posted on Sep 30, 2010
3 Suggested Answers
Vac Belts
  • 701 Answers
SOURCE: my bissell proheat rug shampooer will not realease
That means that you need to replace the pump belt. Here is the belt you need to get it working again:
Bissell Proheat Pump Belt
Posted on Mar 13, 2010
heatman101
  • 43501 Answers
SOURCE: my bissell proheat rug shampooer wont wet carpet at all
heatman101
gfhjdhg
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
Very little suction leaves rug wet.
Check tank and tubes for clogs. Make sure your belt and brush are working. Also make sure you are not overfilling your tank.
800-775-6586
GoodVac com
Feb 24, 2015 | Bissell 2X Proheat 9200 rug cleaner
I have a bissel proheat 2x health home shampooer. It is less than 1 year old and has benn used 3 time andd the brushes will not turn. Is there a reset button, I am overlooking?
If you haven't been cleaning the filters after each use now is the time to get that done. Turn the Flow Indicator Cap counter-clockwise and remove it. Lift the rotor out and under it is the filter. Clean and reinstall in the reverse order. Now under the Water Tank Cap is another filter that looks like a screen. Remove it and clean and replace. Now try your machine. If that didn't do it call Bissell Consumer Care at 1-800-237-7691
Sep 03, 2014 | Bissell 2X Proheat 9200 rug cleaner
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
MY BISSELL RUG SHAMPOOER WORKS GREAT BUT WONT **** UP THE WATER
heatman101
Mar 19, 2011 | Vacuums
My bissell proheat rug shampooer wont wet carpet at all
heatman101
gfhjdhg
Jun 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Dirty Water drops behind shampooer
You are over sudsing your recovery tank. The machine is made to shut off the air flow if water starts to be pulled into the motor, but bubbles want trigger that. So if there are a lot of bubbles in your recovery tank, the get sucked into the motor (Which will destroy it eventually) and then the moisture gets exhausted onto the floor from the motor.
Solutions
1. Use less soap (Read the directions, you may be using too much)
2. Use a different kind of soap (The concentration might not be right for your machine)
3. Use a defoamer (Rug Doctor has a defoamer)
Nov 14, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
151 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
