Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Tankless water heater (Paloma) Has C2 11 error
Starts up and then shuts off after about 5-10 seconds Gas is hooked up
  • mariomadriga Oct 29, 2009
    SOLVED
    Solution # 2 the Cleaning is the problem.
I had this problem with the C2 11 error code. My unit is 1.5 years old. I called Paloma and they emailed me an 11 page document to clean the burners. I am not an HVAC but I got the feeling that's who the instructions were for. Very difficult but you can do it if you're handy. You basically take apart 1/2 the unit, be carfull not to lose any screws and label all the little brackets that come off. It took me 2-3 hours to get to the burners. I used a can of air (for keyboards-electronics) to blow on the burners and clear any build up. After putting it back together (carefull to make sure the 3 gas tubes make a seal when re-installed) the unit works. I did this today so I'm not sure the unit will still work in a week/month. I am dreading having to do this every year to keep the unit running.
Posted on Oct 21, 2009
Testimonial: "THIS WAS THE PROBLEM THANKS"
  • 1 more comment
  • jzollitsch Oct 29, 2009
    "Just wanted to know if the water heater still works after cleaning the burner"
    After a full week, everything still works fine.
  • jzollitsch Jan 12, 2011
    Cleaning the burners the way I described in the first post was only a temporary solution. Just like sjackel, I found myself cleaning it every 3-6 months. In the end, the cleanings only fixed it for a month or so. I've heard 10 different reasons from experts and Paloma/Rheem as to why this occurs. The most common was a poor gas / air mixture. When the unit is warm, the mixture is too rich. Rheem sent me a few replacement parts including a new board but nothing worked.
    Finally I talked to Rheem to go over all the documented problems over the years and how no solution they provided properly fixed the heater. I got them to send me a replacement unit which still needed installation. It wasn't an easy swap since the new unit from Rheem needed special venting (intake and exhaust in a double lined 4" tube). It was intalled as our house was on the market and sold weeks later. I am thrilled I will never have to deal with this again as my new home has a traditional 50 gallon heater, which will be replaced with another traditional heater some day. I will likely never go back to a tankless.
  • drdaveyo Aug 20, 2011
    DON"T EVER BUY ONE OF THESE........THEY ARE JUNK
  • 3 Answers
Clean the air filter even if it looks clean. The air filter is located in the front panel(unscrew knob to open door)...filter looked ok to me but cleaned it under water and that fixed the problem. Note: I cleaned the water filter first and that did not solve the problem. A simple test to see if the air filter is the problem...take the panel door off, press the filter door button and test hot water usage.
Posted on Jul 16, 2010
Just wanted to know if the water heater still works after cleaning the burner ?
johenkel
Posted on Oct 28, 2009
  • 4 more comments
  • johenkel Jun 07, 2010
    Okay, just ran across my old post.
    I did clean the burner and it solved it
    Now 8 month later it happened again. I am taking it apart right now.
    Our unit hangs in our work shop where there is dust.
    I guess I need to protect the intake better.
    Next time we buy a on-demand, I will get a Rinnai system. It draws air from the outside and uses it for the burn. Whole unit is closed off from the location where it is installed. Will work better here. (*mental note*)
    johenkel
  • sjackel Jan 05, 2011
    I had the same problem, but it would only happen after using the heater first. That is, first use after sitting for a while would work then second and subsequent uses would generate error code. I cleaned it out as above and it solved the problem for about 6 months. Cleaned it again and solved the problem for 3 months. Contacted Rheem and they sent out replacement (not sure what the name is - the j shaped spark things) and that solved for about 3 months. After it started failing again they sent out a new circuit board but that didn't solve any problems. After it happened again they said it was an improper installation because it didn't have a condensate trap even though directions clearly state it's not needed as my 6' run has the required downward slope. It now always generates the code and cleaning it out no longer helps. I trhink I've taken it apart about 7 times now in the less than two years I've had it. I will try contacting them again but very unhappy with unit right now. New units have a condensate trap built right into the adapter.
    Cleaning the burners was only a temporary solution. Just like sjackel, I found myself cleaning it every 3-6 months. In the end, the cleanings only fixed it for a month or so. I've heard 10 different reasons from experts and Paloma/Rheem as to why this occurs. The most common was a poor gas / air mixture. When the unit is warm, the mixture is too rich. Rheem sent me a few replacement parts including a new board but nothing worked.
  • sjackel Aug 02, 2011
    I finally figured out what the problem was. Looking at the burners from the front there is a vertical slanted tube on the right sideof the unit right at the front. There are two wires running to what turns out to be some type of probe. I had to completely take the burners out to get at this tube, took out the probe thingy which was black, cleaned it off, reinstalled everything and it worked perfectly. I haven't had a problem since and it's been about 6 months now. I expect at some point it will fail again but at least I can do the extra step and make it last longer.
  • limron Aug 10, 2011
    I had a similar problem with C2 11 error where Rheem went through with me to diagnose the problem. The asked if I use any flex gas hose/line connecting to my tankless ... which I stated yes. The installer installed about 10 feet of 3/4" hose connecting from the 1" main line. Rheem stated the maximum allowable for flex hose is 3 feet. They proceeded to send a replacement burner unit which fixed the problem for about 2 months. I received the c2 11 error message again last week on the replacement burner and called Rheem. The support person asked if I replaced the flex hose.... which I have not. I will look to replacing it the next couple of days with steel pipes and keep my finger crossed that it will fix the problem. As an interim fix, I cleaned up my original burner unit and reinstalled it. It has been working for a couple of day and I'll count my blessing it stays that way until I change the gas pipe.
  • Kent Milberger
    Kent Milberger Jan 26, 2013
    The problem is that you are getting condensation back into the heater from the exhaust line. When it drys it plugs up the gas ports . Stop the condensation from going down into the unit and most all the problem will go away.
    Champion:
  • 248 Answers
Overheat stat or fan best of luck
Posted on Oct 16, 2009
    Problem Solver:
  • 6 Answers
You need the RHEEM TRAINING MANUAL ninja59@peoplepc.com
Posted on Mar 11, 2011
Thermostat is set @120 then drops to 65 and starts flashing. Water get cold. What is the reason . Thanks
Rheem Paloma tankless computer? No error code? One possible cause; Crossover caused by bad single handle faucet cartridge drawing cold water into line causing shut down of tankless burner?
Copy following links for resources:
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment as needed.
Gene
hh
Aug 19, 2013 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My Paloma pg-711fr is turning itself off and error 12 comes up
Copy following link for error codes and Rheem-Paloma tankless troubleshoot.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#error
Add a comment and say if this is new installation.
Call Rheem and hear them tell you to call the tankless installer, or hire local service technician to check your tankless computer that heats water, and catch up on required monthly and yearly maintenance. For example cleaning burner and flame rod, or replacing bad flame rod, or installing correct gas line, or checking gas pressure etc.
Fix any tankless problem yourself, any brand tankless, same day for $385, by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Do not install tankless.
Jul 21, 2013 | Water Heaters
Code P1 appears in my Paloma gas water heater
Copy following link for troubleshoot resources Rheem/Paloma tankless:
http://waterheatertimer.org/images/Rheem-service-valves.jpg
Error P1 is not enough water flow.
Clean water filter located on cold water inlet at top of cold pipe when cold enters unit
Test single handle faucets for crossover
Check if faucet can fill 1 gallon can in 30 seconds.
Apr 15, 2013 | Water Heaters
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
My Boch 24ES Highflow Hotwater is showing Code 14 and only runs for i minute then shuts off
Code 14.
What water heater do you have?
Question posted under tankless Bosch, but these error codes start with a letter.
Rheem/Richmond etc Tankless has error code 14
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Call tankless service technician.
Ask technician how much it costs to have recommended yearly service.
Or install whole new tank-type gas water heater yourself for $350 from local box store, and avoid the entire headache, then sell tankless online for parts.
Aug 09, 2012 | Water Heaters
Error 13 paloma tankless hot water system. no hot water
Before calling service technician, open following links for error codes, Rheem/Paloma chat and tech support, and possible manual:
http://www.fixya.com/support/t3444443-paloma_tank_less_water_heater_flashes
Error codes are considered start-point for troubleshooting.
Tankless manuals recommend yearly service including burner cleaning, gas pressure and plumbing check, de-liming etc to prevent problems and so technician is familiar with that specific unit.
Aug 05, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My unit is a paloma tankless model # PTG-74PVP its throwing error code C4 15 what does this mean? We believe its a flow problem because we hooked up an external pump, it starts out with full flow then...
Could be a restricted inlet pipe just as you suspected.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
error 15 is 'Boiling safety device'
"Check for closed water heater inlet valve or restrictions in cold water inlet pipe (must be fully open).
Check for clogged heat exchanger (scale buildup).
On commercial water heater, lower setpoint temperature below 180F at high altitude."
Open following links for Rheem tankless resources including Rheem chat and phone support:
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Jun 14, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
3,114 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
