Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
550 interior lights
All 4 lights do not work. Bulbs are fine. Is there a fuse or reset for lights??? Cooling is fine.
  • Anonymous Feb 09, 2008
    I have replaced new bulbs and it doesn't seem to work. I think it might be the switch. I am hesitant in taking apart and taking it look at it. If I unplug it, is the only requirement that I wait for at least 5 minutes before plugging it back in?
  • CAAM Feb 23, 2008
    I have replaced the switch in my SubZero 550 after my lights stopped working. Now two of the lights work but not all four. I didn't replace the fan switch - would the remaining two lights be connected to the fan switch? The fan works fine and cooling is fine as well. Thanks.
  • 833 Answers
I'm going to make my first bet on the switch. Usually, this is a plunger unit on the doorframe along the line with the hinges. It is either stuck or burned out. Usually, you can dig the switch out with a small screwdriver. If the switch has only two wires going to it, you can test by shorting out the two wires to each other. This can be done with a paper clip and then taping it up. Since there is power running through these lines, it is suggested that you unplug your unit before attempting any of this. Your fridge should be unplugged for at least 5 minutes before re-connecting. If more than two wires are involved, you can still connect them all together. Sometimes, the fan is shut by a switch when the door is opened. That would be the connection for another wire. If this is the case, carefully note which wires go where before you begin.
Posted on Dec 18, 2007
Is the power supply cord unplugged?
Plug into a grounded 3 prong outlet.
Is a light bulb loose in the socket?
Turn the refrigerator or freezer control to OFF. Disconnect the refrigerator from the electrical supply. Gently remove the bulb and reinsert. Then reconnect the refrigerator to the electrical supply and reset the control.
It worked for me and i did not unplug it as it was a bukit in..i would have turned the fuse off at the box
good uck
Is a light bulb burned out?
Replace with an appliance bulb of the same wattage, size, and shape. See the “Changing the Light Bulbs” section in your
Posted on May 03, 2009
2005 X-Trail interior lighting diagram
If you open other doors besides the driver door do the lights work? If so the door ajar switch is defective in the driver door. Also can you turn on the interior lights from the headlight switch control?
Jul 09, 2016 | 2005 Nissan X-Trail 2.0
Interior Lights not working
In the rear fuse block, check 10 A TBC 3 FUSE 3 and 10A TBC 4 FUSE 40 which control power feed to the body control module.
Nov 11, 2013 | 2002 Oldsmobile Bravada
Kitchenaid refrigerator control panel
Light switch has gone bad use your model number to order a new one
Jul 25, 2013 | KitchenAid Refrigerators
I have a short to ground problem with my tail/crtsy light circuit ( keeps poppin fuses when the light swith is pulled to on position) also dash lights & tail lights don't work but interior light is on...
Try removing the bulbs from the rear tail lights you have one 2 bulb system shorting out, so one at a time remove the bulbs then replace the fuse and see which one is bad or just buy new bulbs and replace, also could be front running light blinker light. But sounds like brake light to ground threw bulb.
Jun 13, 2009 | 1985 GMC S-15
Not your typical brake light problem...
the bmw lights passes through a module called the check control module. it is responsible for giving a warning if the bulbs are busted. it must be the module
Jun 03, 2009 | 1996 BMW 318
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
377 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
