Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
My computer will not recognize my hard drive when I turn it on
  • 35 Answers
Try other usb ports on your computer. if that doesn't work then try it on another computer. i say that because the hard drive could be damaged. if it works on another computer then you need to make sure you have the proper software installed on the computer you want it on. like the drivers. they usually can be found on the products web page by typing in the model number.
Posted on Sep 28, 2009
My hard drive is not being recognize
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 06, 2013 | Computers & Internet
Computer won't recognize external usb hard drive
Format drive NTFS sounds like its corrupt, use mini partition wizard...
may also need 3TB Unlocker from manufacturer of Hdd
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
I bought a 3.5 External hard drive enclosure for a 1TB hard drive. The PC recognizes it but not under the removable drives
right click on "My Computer" and select "Manage". Then go to "disk management" once loaded you will see your drive. You probably have to initialize the drive and assign it a drive letter. all that can be done from right there.
Aug 09, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
My computer is not recognizing my acomodata external hard drive
Can it work in another port or another computer?Try these option if all fails maybe the device is bad.
Oct 02, 2009 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
My drive is not recognized
I've had this problem before.
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Jun 27, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
My computer has ceased to recognize the drive.
you should check that the connecting cables are connected properly to the mother board.
May 13, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Problem with sandisk 2GB Micro USB Flash Drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Jan 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
105 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
