Question about LG Shine KE970 Cellular Phone
CAN NOT UNLOCK EXTERNAL MEMORY FORMAT - LG Shine KE970 Cellular Phone
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
My polaroid DVF-720 digital camcorder wont turn on.the battery is fully charged and it is in the right way.
1.Remove battery
2.Remove memory(EXTERNAL MEMORY)
3.Plug in the power ,CLICK BUTTON ON in 10 second.
4.Plug out the power
5.Insert back battery.
6.Click button ON IN 10 SECONDS AGAIN.if it will ON MOVE TO STEP 7. IF NOT,GO TO STEP
7.OFF CAMERA AND THEN BACKUP YOUR MEMORY(EXTERNAL) to pc
8.CHECK AND FORMAT
9.INSERT BACK EXTERNAL MEMORY
10. ON BACK AGAIN.
11.TRY CHANGE BATTERY . SOMETIMES BATTERY WAS ISSUED FOR THAT. IT NEED OPTIMUM POWER. BATTERY FULL DOESN'T MEAN THAT IS OKAY.
however, mostly issue are cause from external memory, if that can ON without external memory that mean your memory was problem. backup, checking disk.
FORMAT, USING PC .IF SUCCESS IN FORMAT USING PC, THEN FORMAT AGAIN IN YOUR CAMERA. IN FORMATTING USING PC, TRY USE FAT32 THAN FAT.
TRY IT...out
May 28, 2011 | Cameras
Showing Error 5 all the time. Can't take pictures
This will take longer to write then to do it. Error 5 in my experience can be memory card, internal flash or actually an unlocked lens. The lens unlock button is pretty big and sometimes gets pushed in as my clients are zooming or twisting the barrel somehow. What I've had to do is shut the camera off, remove the battery. Unlock the lens ( I wait a second or two) then lock it back in place. Another problem was having an external flash installed and hit the internal flash button. The number 1 problem I've found was the Memory card, either it was (is) a new card that hasn't been formatted to the camera, a memory card that was formatted in the computer (that really messes with their brain) and another thing was continually using the delete button on the camera, or if it's a new card and you have formatted it and formatted it again and it still doesn't work try another card.
Okay the last suggestion and what actually happened to me on my Canon EOS 1D Mark II and III I was using 4gig cards bought 8 gig cards and went nuts cause they wouldn't work. Went on Canon's site and downloaded the updates which ended the problem.
Dec 10, 2010 | Canon EOS 40D Digital Camera
I want to format my nokia 5220 music express mobile.
sir go to the applications option and select the memory status left click and select the format option to format.or connect to the pc and format the memory card memory and the external memory to format...........
Nov 24, 2010 | Nokia 5220 XpressMusic Cellular Phone
Unable to format the 2GB Memory card. Message occurs : Windows unable to complete the format.
A hidden application is disrupting your format process download "unlocker" software application from google, install it then right click on the memory card icon you find unlocker option double click n press unlock all after this try formating your memory card will work fine
Sep 20, 2010 | SanDisk 2GB microSD Memory Card
Format external memory
the problem can be solved.For the video not to be able to play might be due to the video file being corrupted or the memory card was not really formatted properly.
You can format the memory card again and try transferring the file into the memory card.If it does not work, try and use another device to format it.
If still it does not respond properly, then the memory card is corrupted and it needs to be replaced.
Have a nice day.
Mar 16, 2010 | Insignia Sport MP3 Player
I TRY TO ACCESS MY EXTERNAL MEMORY AND IT SAYS '' BAD FORMAT ERR
re-format the memory or try to read the content from another device first. Use the latest drivers and update your firmware.
Aug 31, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
New sd cards reads memory full
Try to format the card. If possible, use an external card reader attached to a computer.
Make sure the card is unlocked (with the switch on the side of the card).
Have you managed to have other cards working on the camera?
May 07, 2009 | Kodak EasyShare C330 Digital Camera
Please help, i cant activate use of my memory card on the lg viewty
If its a new card, have you formatted it in the phone? (go to Menu, Settings, Phone Settings, Memory Manager, External Memory then click on the Format button).
To activate its use, go to Menu, Settings, Phone Settings, Memory Manager, Primary Storage Setting and select External Memory.
Apr 16, 2009 | LG KU990 Viewty
LG Shine KE970 Cellular Phone Logo
61 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
