Question about Numark DM1200 DJ Mixer
DXM09 MIXER ADAPTOR
HI, MY POWER SUPPLY DOES NOT WORK!! ANY CHEAP SUGGESTIONS FOR REPLACEMENT?
  • Numark Master
  • 5,603 Answers
Often the cord has broken wires. First try to repair the power supply.
Also check the connector in the mixer as they can get damaged by side pulls of the cord.
Posted on Sep 28, 2009
MX3282A. Where can I get a power supply?
Hi Bryant...
That particular power supply is hard to come across. There is a brand new one for your mixer on E-bay for $200.00 here:
http://www.ebay.com/itm/Behringer-Eurodesk-150-Watt-Power-Supply-For-Mixers-MX2442A-MX3282A-NEW-/252274097139
Hope this has helped you.
Jan 27, 2016 | Music
I have a pmp 5000 and i run crown power amps...i lost effects on my monitors and my mains seem to have distorsion...
Assuming you have not got the fx1/2 to mon turned right down it would seem likely that this has failed which would be about the only thing that would stop fx to mon if all else is working. You do not describe the distortion to the mains but if it is related to the fx then this would point to the same thing, a failed pot probably. These are a total nightmare to replace although the part is dirt cheap. Allow your self several hours if you think it is worthwhile. Behringer (and some other) mixers are now made in such a way as to be almost unrepairable using a single smt board that requires total disassembly of the unit to replace even wearing parts (excluded by the warranty). I would suggest replacing the mixer with a new one or a decent second hand one.
Oct 14, 2013 | Behringer Europower Pmp5000 Powered Mixer...
Connected wrong voltage power supply to my mixer when in Hong Kong.
If you have the polarity correct for the connector, and adequate output from the transformer with adequate regulation and filterning, there should be little problem with constructing one or hacking the cord off the dead supply and wiring it to a new one.
The question you need to ask yourself is whether that wait is worth it? If you need it to make money with it right now- then just use care in wiring the new supply up. I have lost track to how many times I have rewired a supply to make it work on something it was not originally on. As long as the specs on the new supply match those of the old one- no problem..
Sep 24, 2012 | Behringer Xenyx 1202fx Mixer 12 Input 2...
On my Behringer UB1202 mixing board none of the inputs work. I plug headphones into the headphone jack to monitor. Neither dynamic nor condenser microphones work (with phantom power enabled when...
Does your computer Recognize the mixer. and to answer your question honestly Behringer is Junk they make cheap knock offs of really expensive products. but see if your computer recognizes it and if not i sugguest taking it back
May 13, 2011 | Behringer XENYX 1202 Premium 12-Input...
Hello, I need assistance with my vestax pcv002 mixer. i need to replace the power cord since it has gone missing. Can i get just any generic DC15-A power adaptor or not? the proper vestax ones are much...
Provided the store which sells the universal type guarantees the voltage and current factor as available on the original Vestax, you can proceed to buy the type.
Also the product must be a good one to work without heating or have reduced life due to poor quality.
Mar 18, 2011 | Vestax Dc15a Power Supply
I need help on changing a fuse in PMP3000. The mixer went out on us one day, so I hooked it into an amp that we had. It works good as an unpowered mixer, but cannot get it to work as a powered mixer. I...
No, that is NOT what the problem is.
The fuse protects the power supply. The power amps have failed. The usual cause is an arc between layers of the multi-layer circuit board. The labor to repair the power amp module is extensive. I have repaired several.
You can find new amp modules and I would purchase a new one and drop into your unit. The amp module is an HCA2400.
There is probably $15 of parts blown in each side of the power amp and it takes about 6 hours to repair. One has to grind out the burned area (internal layers not necessarily visible on surface) and re-insulate and then install jumper wires to replace those taken out.
Each side of the amp will likely take out 3 switching MOSFET transistors and often a Zener diode. Sometimes a low resistance metering resistor will be fried with smoky residue underneath the board. When this happens two small surface mounted resistors will be blown open. Great care has to be taken when insulating the board damage and replacement of the blown circuit traces.
You can find HCA2400 power amp module replacements for about $175 online.
Use of the unit as an unpowered mixer is a bit dangerous as if arc re-establishes it can fry the power supply taking out two very expensive IGBT's and many other components. If the mixer still works, then your whole power supply is still OK.
Sep 09, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
May 18, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Power light comes on but nothing else works.
There is a possibility that your plug on the adapter is the wrong polarity. See if the polarity is marked on your mixer by the power adapter jack.
Feb 03, 2010 | Vestax Pmc 280 DJ Mixer
Numark 360 21v 750ma Power Supply
Try the following sites
http://www.powerstream.com/power2.html
http://www.platinum-records.com/Numark-21V-750MA-AC-Adapter-Power-Supply-prod7509.htm
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
Aug 10, 2009 | Numark DM1200 DJ Mixer
Numark DM1200 DJ Mixer Logo
295 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
