Question about Dishwashers
Fills with water but will not cycle past that.
The dishwasher fills to wash but then fails to cycle past that. The control panel clicks and then after awhile the lights on the washer begin to flash. I touch the drain button and get same results I have taken out all filters and there aren't any obstructions there..
  • 19,396 Answers
Check the water level switch and sensor. If this is the floating sensor type, ensure that is not stuck. The WL can be tested by a technician jumping its contacts. After water level, the impeller pump must be tested, energizing it , and eventually unblocking the hose connected.
If the problem happens right after filling, then it can be a water level/pressure switch problem, a faulty pump, or a faulty timer board.
Posted on Sep 28, 2009
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
I have a problem with my Asko D3350 Dishwasher, can you help? On startup the diswasher does its normal cycle and pumps excess water out and then fills the dishwasher with water to the correct level of...
Hi Tony,
I have the same machine (D3350) and almost the same problem.
Mine starts each cycle fine - pumps out - fills - rinses - pumps out tht first load and then does not fill again. If I manually fill with a bottle (about 2 litres) for each subsequent cycle then it washes as well as it ever did.
Seeing it fills once it cannot be the water supply, nor the solenoid that operate the water supply. So, my guess is the control panel.
Like you I would love to simply take advantage of the PC Upgradeable featurewshich seemed so attractive at the time of pruchase.
Jason
Dec 31, 2010 | Asko Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Apr 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
