Question about Apple iPhone Smartphone
Screen magnified how to put back to orginal setting
    President:
  • 239 Answers
Double tap the screen with 3 fingers and it will unzoom. Then to switch the feature off, go to settings, accessability and turn off zoom feature.
Hope this helps and if so please vote.
Thanks
Jim
Posted on Oct 09, 2010
When i try to play the game scrabble the screen magnifies and i have double tapped but it stays magnified. I have tried several different things to have it go back to normal
You need to "Pinch" the screen. Place thumb and forefinger anywhere on the screen and pinch them together while continuing to touch the screen.
You can do the reverse to magnify the view. Place thumb and forefinger on the screen near one another. While maintaining contact with the screen, spread them apart. This gives a more controlled level of magnification than tapping.
Feb 09, 2015 | Tablets & eReaders
,hi, I have a slight problem with the desktop.The desktop became bigger than the screen.I tried to put it back many times and could not.
I think what you have done is accidently magnified your screen slightly. To correct this hold down your ctrl key and move your finger on the mousescroll button back. Hope this helps.
Jan 16, 2011 | Computers & Internet
Hi i forgot my users password an i cant reestart the laptop its a dell laptop windows7 home premium can u help me restart the computer
There are 3 options for your problem:
1. You can boot to WinRE(Windows Recovery Console), run the command prompt. Go to the WINDOWS directory. Rename magnify.exe to magnify.old. Rename cmd.exe to magnify.exe. Restart your computer and boot normally. On the log in screen, click on Ease of Access. Select the option for magnifier. It will open command prompt instead of magnifier. Type the command: control userpasswords2. It will give you the option to reset the password.
2. Run in safe mode. Log in using the profile Administrator. Go to control panel then user accounts. You can change the password of your profile.
3. Dell systems have the built-in factory image restore. It can be found in the WinRE. To go to WinRE, turn system off, power on computer, after pressing the power button, tap on F8 till it gives you a screen that says Advanced Boot Options. Select Repair your Computer. Click on a few things for the language. Then you will have a window that says Windows Recovery Console. Click on Dell Factory Image Restore. Then there you go! it will restore the system back to its factory settings.
Hope this helps!
Sep 08, 2010 | Computers & Internet
My arrow turned into a magnifying glass. How do I change it back?
On the Start menu:
Point to All Programs.
Point to Accessories.
Point to Accessibility.
Select Magnifier.
Notes A message box with a link to more information about Microsoft Magnifier may appear. To close the box, select OK.
To use Magnifier but hide the Magnifier Settings dialog box, select the Minimize button.
To turn off Magnifier, in the Magnifier Settings dialog box, select the Exit button
Jun 03, 2010 | Logitech Cordless Mouse
Using outlook or word with Windows 7 PC, font size will suddenly change. Why? Magnifying glass pops up, unasked, by cursor. Annoying. Why? thanx for any help
Hello!
It sounds like Windows Magnifier is turned on, which is one of the tools available through the "Ease of Access Center".
To quickly exit the Magnifier (for the time-being), press the Windows key + Esc simultaneously. This key combination toggles the Magnifier on/off. (Windows key has the Windows Logo on it, usually between the left-sided "Ctrl" and "Alt" keys on typical keyboard).
To disable the Magnifier altogether:
Ensure you are logged in as an administrator or user that is a member of administrators group.
Click "Start", then click "Control Panel". Then click a blue & white icon labeled "Ease of Access Center". Look below the initial "Quick access to Common Tools" boxes at top of page, to a section called "Explore all settings". Click on the link "Make the Computer Easier To See", which brings up the section which pertains to the visual display. At the bottom of that page, there is a section labeled "Make things on the screen appear larger, below it a link, then a check box "Turn on Magnifier". Uncheck this box, and ensure nothing else on the page is checked. Click "Apply", then click "OK".
This should turn off the magnifier completely for the system. For future reference, should you ever need the Magnifier tool, you will see a small magnifying glass icon on the taskbar - click that to open the Magnifier toolbar, and you can then set how the magnifier works and where it works, and whether or not it follows mouse movement or is docked. Handy sometimes, as things on some screens can be rather difficult to read when print is especially tiny. If you have the issue of not being able to read icons or their labels on the desktop, or on the system as a whole, you can adjust this by opening "Control Panel" and then "Display" - where you can set the screen text and icon sizes to "small" "medium" or "large" to suit your needs - it's much easier and alot less annoying than Magnifyer can be - just something to keep in mind should you ever need it.
Hope this info helped you! If for some reason you have any additional problems, or get stuck, please come back and let us know...best of luck!
May 06, 2010 | Computers & Internet
My screen magnifies too much after downloading games making it impossible to use till it has rested for some time .The magnifier cannot be seen at the time
I don't think it's the magnifier. Many games change the resolution of the screen whila playing the game, but then they fail to return the screen to the same resolution it was before. To solve the problem, right-click the mouse on an empty part of the desktop, when the manu appears, select "properties", then the tab labeled "settings" and manually set the correct screen resolution
Mar 17, 2010 | Toshiba Satellite Pro L350-S1001X Notebook
Reducing the enlarged screen with the magnifier
Have you tried scrolling the mousewheel while holding down the magnifying button?
Nov 12, 2008 | Microsoft Wireless IntelliMouse Explorer
Magnifying glass
use the left button on the side (the same one that turns it on), but you have to click quickly, because if you hold it down (as i did), you only get the option to change the dimensions of the magnification area.
Nov 06, 2007 | Microsoft Wireless IntelliMouse Explorer
Apple iPhone Smartphone Logo
78 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
