Question about Denon Audio Players & Recorders
My Denon AVR-1507 keeps automatically turning off every time I turn it on. Then the standby button blinks red. Is there a quick fix to reset the microprocessor?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Store these instructions in a safe place. After reading, store these instructions along with the warranty card in a safe place. Whenever the power operation button is in the STANDBY state, the unit is still connected to AC line voltage. Please be sure to turn off the power operation button or unplug the cord when you leave home for, say, a vacation. Note that the illustrations in these instructions may differ from the actual unit for explanation purposes. Please click on this link for further reference---
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 28, 2009
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
DENON AVR 1507 short?
unplug it, let it set for about 15 min., plug it back in and see what happens. Hopefully it will recycle itself. If that fails, with your theater remote, you can pull up it's functions screen on your TV, and probably return it to factory default settings. That would be a last resort for me before seeking professional help. Good luck. . .
Jul 27, 2017 | Denon AVR-1507 Receiver
Denon AVR-1507 speakers don'twork is there something I can reset
Yup, don't guess, read. Lots of things to set.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1507-Receivers-manual/id/696ci071/t/2/
Mar 14, 2011 | Denon AVR-1507 Receiver
Denon AVR-1507. Worked one night, wouldn't work the next night. Nothing is coming on at all. No known reason just not getting any power. Any ideas on what to check out? Is there a reset button, is there...
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Dec 08, 2010 | Denon AVR-1507 Receiver
The Denon AVR-1507 switches off and power light blinks red. Its a cool unit and ventilated so no idea what the issue is. This happened when it was off over night. What is the solution. Manual says send to...
Before you send the unit to the service center, check the wiring. Make sure that the speaker wires don't have loose strands that are touching each other or touching the rear panel of the AVR-1507. Check all of the speaker wire connections for loose strands. Since the receiver is minimally used, you could try vacuuming out any dust from the interior of the unit. Note: if the receiver is still under warranty, opening the case to clean it will void your warranty.
If the problem persists, a service center is the best option unless you are very skilled at fixing electronics. Manuals Lib does have a service manual for the AVR-1707, AVR-1507 and other models. However, there is a notation that individual illustrations may not match the receiver being worked on. A Google search can lead you to this manual.
I hope this helps.
(In some environments, electronic equipment can overheat when insects or dust get into the unit.)
Feb 27, 2018 | Denon AVR-1507 Receiver
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Apr 05, 2009 | Denon AVR-1906 Receiver
Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Jun 27, 2008 | Denon AVR-1705 Receiver
598 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
