Question about Lanier 5222/27 Laser Printer
Do you know how to set the ip address on a Lanier 5222?
4 Suggested Answers
lserni
  • 466 Answers
SOURCE: Change delivery server IP Address
I had this problem with an Aficio 2018D using scan router ScanRouter V2 Lite. The MFP would say it couldn't update the delivery list. Deleting/Reinstalling SW, resetting the I/O device and so on, nothing worked. At last I had to use the SP 5845 (see maintenance manual) to manually change the Delivery Server IP address, which was initially set to 127.0.0.1 and had by then been corrupted to 0.0.0.0, to 192.168.1.227 which was the IP address of the WinXP where ScanRouter was running (of course port 3870/tcp must be opened as exception in Windows Firewall). The scanner immediately "saw" the delivery list, updated by itself and, touching wood, worked like a charm ever since.
Posted on Jun 05, 2009
Joed911
  • 4338 Answers
SOURCE: setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 06, 2009
  • 393 Answers
SOURCE: I need a nic for a lanier 5222
WE can get you a Nic card but they are not free. (quennie@wcvt.com)
--Carl, let me know if this helps.
Posted on Jun 27, 2009
Why can't I print on cloud print with my canon inkjet mp830. It keeps saying "printer offline"
Hi, you may find that opening port 5222 in your router settings corrects this for you. This is due to Google Cloud Print (GCP) needing to poll your printer, if the port is not open then GCP will not get a response from your printer, therefore will show it as offline.
It is also possible that your firewall is blocking communications so you would need to open the same port (5222) in your firewall / antivirus software.
Warning: Ports are often closed on a router to help prevent unauthorized access to your home network. Opening any additional ports on your router may decrease the overall security of your network.
  1. To use port forwarding first determine the local IP address of the computer or device you are forwarding the port to.
  2. Open your router configuration / settings menu.
  3. Once in the router configuration locate the port forwarding settings, often in a section such as Applications & Gaming or Port forwarding. I would suggest that if you are having difficulties with this to refer to your router documentation or call their support line.
  4. You will only need to open port 5222.
  5. Give your new rule a name that you will recognise.
  6. Next enter the port number 5222, if you are asked for Externet and Internet enter 5222 in both.
  7. The protocol is TCP.
  8. Next is the IP address of the computer.
  9. Don't forget to check the enabled box if there is one and save changes.
If you have any issues with this I would suggest Port Forward web site where specific instructions should be available for your router.
Tom
Jan 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
My lanier is making dark copies
One of the most common reasons for a Lanier 5222 or 5227 to make dark copies is a problem with the drum unit or developer. Fortunately on those machines, the drum unit and developer are all self-contained in one easily-replacable unit, called the PCU (photoconductor).
If you don't have a new PCU handy, you can order one from the same company you get your toner from. The PCU should generally be replaced every 60,000 copies, but sometimes it may need to be replaced sooner (especially if you run a lot of dark copies or make a lot of copies of images) and it can often run longer than 60,000.
Replacing the PCU is easy -- it sits right next to the toner bottle, and all you have to do is slide the old PCU out and slide the new PCU in (once you remove all of the tape and other trappings from it). Instructions will be included in the box with the new PCU.
Please rate the effectiveness of this solution. Thank you!
Oct 10, 2010 | Lanier 5222/27 Laser Printer
Scan routing
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/x22_27/x22_27en.htm
Go to the above site and download your software and a manual, the manual tells you exactly how and what to do.
May 21, 2010 | Lanier 5222/27 Laser Printer
Lanier LD016 can't scan to server using server name but can scan to server using IP address on server 2003.
Your DNS information may be incorrect use a ipconfig /All to check your DNS setting from any workstation on your current network. If you ping the name of the server it should reply with the IP address
Feb 13, 2010 | Office Equipment & Supplies
Lanier 5527 that is displaying SC541
This is a fuser error, you will need a service call.
Feb 01, 2010 | Lanier 5222/27 Laser Printer
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
Feb 27, 2009 | Lanier 5222/27 Laser Printer
Lanier LD 024c
You need to check the DNS server. Press user tools, system settings, interface settings. This screen will display IP address settings. There is a DNS selection. Put the Ip address for the DNS in there. (obtain by, Windows desktop screen, Start, run, type cmd in the input box, enter, at the prompt, type ipconfig /all. it will bring up your settings. write down the DNS setting.)
Now, your SMTP server setting can be obtained by going into your Email account settings. There will be a spot for servers. If you are using Microsoft exchange server, you can use the server name or its IP address. Otherwise, it will be your ISP email server setting. You can just call your ISP and get the outgoing server name. Once obtained, go into user tools. system settings, file transfer and plug in into the SMTP option. I think if I'm not mistaken, there is a connection test there as well. (The 024 might be too old to have that) That should do it. You may need to enter in a email name and password for athentication.
If you have any problems, you can call the Lanier help desk too. 800-424-1573
Apr 14, 2008 | Office Equipment & Supplies
Printing to an LC031
The mini centronix port is used to update your fiery. You need to set up an IP address, Subnet address, and gateway on the fiery. Then go to WWW.lanier.com, and download the LC031 print driver, or E7000 fiery I believe. You may want to check the fiery model. Then is a matter of installing the driver, and pointing it to the IP address.
Dec 27, 2007 | Office Equipment & Supplies
629 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
