Question about HP OfficeJet 6110 All-In-One InkJet Printer
Cartridge Latch Cracked
The cartridge latch w/spring that holds cartridge in place is broken. The plastic cracked and because it is designed w/a spring that adds pressure to keep the cartridge in place, we cannot simply repair it. Where can we get a replacement piece? All else works fine.
2 Suggested Answers
  • 137 Answers
SOURCE: HP 7410xi small plastic piece in print cartridge carrier broken
If the spring did not damage the carriage flex I would suggest just using some epoxy to hold the spring properly in place. If the spring did damage the flex (as shown in this picture) then you might contact HP and enquire about an extended warranty for this issue. In the US call HP at 1-800-HPINVENt.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Mar 02, 2009
Frigidaire Gallery Microware door doesn't latch
I experienced the same problem. The solution was easy, for me at least. Remove the door. pry loose the plastic liner that covers the inside of door. remove the four screws that hold the glass unit in place. You will find rattling around inside a spring about an inch long and a broken plastic piece about an inch and a half tall. On my unit the plastic piece was still hanging on by a thread which gave me a clear understanding of how the door latch is supposed to work. Remove the plastic latch unit which is designed to slide on the two posts about three eights of on inch distance under the pressure of the spring. Problem is loss of spring induced pressure.
The repair: ( I used my bandsaw to do this) fashion a piece of wood with indentations that correspond to the plastic ribs enabling the wood to sit perfectly into the space. Drill a hole at the point where the inch and a half "anchor post" broke off and insert a dowel of same length. I carved a shallow indentation for the spring, pressed the spring on with needle nose pliers, replaced the sliding latch mechanism, attached other end of spring to the latch. I drilled into the exterior plastic door frame and installed a flat head screw to hold the wood repair piece solidly in place. Re-install pieces removed earlier and you have a happy, functioning Frigidaire gallery micro at your service. Took an hour.
Apr 06, 2014 | Frigidaire Gallery FGMV174KF 1.7 cu. ft....
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do you replace the ink cartride in a hp 2175 all in one printer
1. Prepare the replacement cartridge by pressing down and back on the top of the protective plastic, then sliding the cartridge out.
2. Set both the cartridge and empty cartridge protector aside.
3. Turn on your printer and lift the access door until it locks into place. The print carriage will move to the center.
4. Once the print carriage has stopped moving, raise the latch to release the empty cartridge. 5. Remove the empty cartridge by pulling towards you. If you are replacing the tri-color cartridge and need to remove the black ink cartridge temporarily, use the empty cartridge protector to hold it. 6. Hold the replacement cartridge by the sides and remove the black plastic tape. 7. Insert the replacement cartridge into the appropriate slot (left for tri-color, right for black) until it snaps into place. 8. Pull the cartridge latch towards you and press down until it snaps into place. 9. Close the access door. -------
You may also download and refer to it's product manual :-
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
and
http://h10032.www1.hp.com/ctg/Manual/bpu73554.pdf
Sep 25, 2010 | HP PSC 2175 All-In-One InkJet Printer
Plastic piece in front of the cartidge prevent cartridge removal
Please have a look at this support tutorial. I think you will find that the plastic piece is the cartridge latch which holds the ink cartridges in place.
HP DeskJet 6988 Replace Cartridge
Jan 09, 2010 | HP DeskJet 6988 Printer
I need to remove/replace cartridge,i dont know how?
Hi!
This link guides you on how to replace the cartridge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&product=79477
Replacing the print cartridges
  1. Turn on the power.
  2. Lift the print carriage access door on the front of the unit, just above the output tray. The print carriage will move into the middle of the access area. Figure 1: Raising the front access doorc00004385.jpg
  3. Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch and then pulling the lower section of the latch forward. Lift the latch.
  4. Grasp the sides of the ink cartridge and pull the cartridge out to remove it. Figure 2: Removing the cartridgec00004386.jpg
  5. Remove the replacement cartridge from its packaging. Touching only the black plastic, remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tapec00004387.jpg
  6. Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage as shown below. Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch). To install the optional photo cartridge (HP 58) for six-ink photo printing, remove the black print cartridge (HP 56) and insert the photo cartridge (HP 58) instead. Figure 4: Inserting the cartridgec00004388.jpg
  7. Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur. Figure 5: Latching the ink cartridges in placec00004389.jpg
  8. Close the print cartridge access door. Figure 6: Closing the access doorc00004390.jpg
  9. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Nov 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I can not get one catridge of my 7210 to come out is there a easy
bwiselady -
If it doesn't pop out when you lift the latch, your return spring may be stuck, bent, or broken. Try pushing the cartridge in gently, and put the latch down over it. Then try to lift the latch and see if the spring pops the cartridge out.
If that fails, lift the latch and remove the other cartridge. Then, lift the latch on the stuck cartridge and try to gently pull it out. This won't cause any damage unless something is snagged on the cartridge, which is not likely. If you feel a lot of resistance when trying to pull the cartridge out, there is something very wrong, and you shouldn't proceed. Then take it to someone with experience fixing the printer.
Here is the HP support page for your printer:
http://h10025.www1.hp.com/ewfrf/wc/product?product=391153&lc=en&cc=us&dlc=en&lang=en&cc=us
Michael
Jul 15, 2009 | HP Office Equipment & Supplies
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Microwave door doesn't shut
I answered this personally via e-mail (and I do not mind peopke writing me personally). I think you may have a broken tab which holds the door latch head spring in place.
Oct 19, 2006 | Sharp R-1481B Microwave Oven
HP OfficeJet 6110 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
