Question about Cameras
1996 s10 2.2 rough idle will not accelerate - Cameras
SOURCE: 1996 Buick Regal
gas pump
Posted on Jul 23, 2008
  • 156 Answers
SOURCE: 1996 FORD CONTOUR 4CYL ROUGH IDLE ROUGH ACCELERATION
no problem. If you are getting that low of voltage on a load then you might want to test the alternator as well to make sure it is running at capacity.
Posted on Feb 23, 2009
countrysi248
  • 443 Answers
SOURCE: rough idle, backfire on acceleration
check everything you can under the hood your air intake system all of it especially make sure all clamps are tight .. and make sure all vacuum hoses are good and not cracking or broken or just loose . you might run a little fuel cleaner through a tank of gas too cleaning the engine fuel system up some. just a few ideas.. Jerry
Posted on Apr 12, 2009
  • 1619 Answers
SOURCE: 1996 MERC 220 HAS ROUGH IDLE AND POWER LOSS ON
Coils, wires, plugs, fuel filter. A real tune up in other words.
Posted on Apr 14, 2010
samtoler
  • 666 Answers
SOURCE: 96 breeze 2.4 l cat convertor plugged? rough idle - wont accelerate beyond fast idle and stalls
You can add whats known as a "Test Pipe" To verifie that is the issue, Or simply disconnect the cat and drive it around the block. Although you can bypass it, Its NOT reccomended you do so. Hope this helps..
Posted on Oct 29, 2012
My 96 ford bronco runs rough on acceleration,idles fine. Runs good under light acceleration but if hit the gas hard runs bad and pops. Changed fuel filter no change.what next?
givit a tune--new distributer cap--new plugs and cables--------also have air intake cleaned plus idle control--use a nonchlorinatd solvent sold a napa etc
Jul 22, 2014 | 1996 Ford Bronco
Rough idle smooth accleration
Check your vacuum lines and be sure your throttle body is tightened down. Carb cleaner spray can be used to find the leak. Spray it around the lines and gaskets (while the engine is running). If the idle speeds up, you found the area of the vacuum leak and the solution to your problem, possibly.
Jun 25, 2014 | 1996 Buick Century
1996 crown victoria misfiring loss of power under light to heavy acceleration, rough idle
The plug wires on this model year and prone to burn through, replace them all, do one at a time and always put them back in the factory wire looms they run through, that is very important, replace any you may break. Use high qyuailty oplug wuires foractory parts are preferred..
Jun 07, 2013 | 1996 Ford Crown Victoria
92 NISSAN WITH BOGGING AT 2800 3500 RPM AND AT LEVEL SPEED 4CYL AND 5 SPEED
For this types of problem,there are few help inks to troubleshoot the problem.Click the link below to go through the troubleshooting procedure to resolve the issues :----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------------runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
-----------Car still runs Rough after tune up? http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
------------Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
----------High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
------------Engine Backfires? http://technoanswers.blogspot.in/2012/02/jeep-backfires.html----------- Nissan stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
Feb 17, 2012 | 1992 Nissan Pickup
4.0 liter v 6 idles very rough
Rough idle is usually a symptom of a vacuum leak especially if the engine runs good at full acceleration. You have 14 year old vehicle, so check all under hood vacuum hoses.
May 23, 2010 | 1996 Ford Explorer
Apr 05, 2010 | 1996 Mercedes-Benz C-Class
Feb 23, 2009 | 1998 Ford Contour
4.9 liter will idle but wont accelerate have to start with ether
yes checked fuel pressure and replaced the fuel filter, checked the mapp sensor,tested throttle position sensor, has strong spark, 50psi fuel pressure, fresh tune up, runs real rich and rough idle but wont rev up like fuel injectors arent speeding up, also checked exhaust. thanks julius
Oct 09, 2008 | 1990 Ford F150
Cameras Logo
82 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
