I already changed out the ink and i set the slef clean it still does not print
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Black ink will not print on my HP 5610 inkjet
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
SOURCE: Xerox 8500 excessive ink use
Hello Phaser 8500 owners,
I found a way to restrict the wasting ink problem of excessive cleaning cycles:
Just unplug the connector of the ink pump. One can find this pump behind the left plastic cover. Unplug the connector of the pump during the excessive cycles and put it back on again after.
To my experience the cleaning cycles come too soon or too often.
Good luck,
Tim
Posted on May 09, 2011
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Ink appears very light. Already changed all ink
Access printer software and perform "print head clean"
Jan 26, 2010 | Brother Office Equipment & Supplies
HP 640 Fax series not printing
If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
Hope this helps...
~enov8
Feb 16, 2009 | HP 640 Inkjet Fax Machine
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
Printing not complete
you may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
One of the reasons this could be happening is because you are using non-xerox ink so your print head needs to clean it out much more often. Be careful using other ink as this can destroy the machines printhead which is more expensive then the machine itself to replace. What you could try is installing the new printhead firmware, it might help! Follow the link below and good luck!
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8500_8550&country=United%20States&language=en
Niallbt
Jan 09, 2009 | Xerox Phaser 8500/DN Printer
Poor print image
You use your printer settings to set quality of image.
Jan 31, 2008 | HP Photosmart D7160 InkJet Printer
Black ink not printing
if the black never print anymore but that is new clean the printer head.or go on start programs click printer or faxes, installed will appear right click on the printer name proterties go on service then then box will appear u can their the word allign cartrigde an clean.
Aug 23, 2007 | Canon S200 InkJet Printer
13 people viewed this question
k24674
jasbo
jasbo
