Question about Epson GT 7000 Flatbed Scanner
Can someone advise if the Epson GT-7000 scanner which I had working in XP can be made to work in Windows 7 or is it time to throw out my faithful machine? Rodney.
  • 5 Answers
I got mine working on Windows 7 (x64) by doing the following:
1. Download the Windows 7 Epson Scan driver for the Perfection 2400 from the epson site 2. Install the drivers 3. In Start Menu->All Programs->Accessories right-click Notepad and select Run as administrator 4. In Notepad File->Open and browse for the es27.inf file located in C:\Program Files (x86)\epson\escndv\es0027 5. On line 51, 54, and 57 replace PID_011B with PID_0101 6. Save the file. 7. Connect and turn on the scanner. 8. In Device Manager (Start Menu, right-click Computer, select Properties, Device Manager) right-click the scanner and select Update Driver Software->Browse my computer for driver software 9. Select the location of the modified INF file (C:\Program Files (x86)\epson\escndv\es0027 Include subfolders checked). 10. Say ok to the window that pops up and it should start installing the drivers.
In Photoshop you should then be able to import using WIA-Epson Perfection 2400 (importing with Epson Perfection 2400 causes Photoshop to freeze)
I hope that works for you :)
Stephen
Posted on Jan 22, 2010
You may download the GT-7000 WinXP driver and install. The problem on using the XP driver is an error appear every time you access the TWAIN driver and the scan profile cannot be saved.
By modifying the security of the driver folder, the error can be eliminated.
1. Download XP driver from EPSON support site. e.g. http://www.epson.co.uk/Scanners/Epson-GT-7000/Drivers-Support?_DARGS=/jsps/support/modules/mainContent.jsp#
2. Install the driver normally
3. Change the security of the folder of TWAIN driver. e.g. C:Windows wain_32EPFB3. Put 'allow write' for the 'users' group.
4. Create a blank text file 'estwn323.ini' in C:Windows folder and set security of this file to 'allow write' for the 'users' group.
After that, your scanner will work normally. Cheer~
Posted on Apr 16, 2010
    President:
  • 1,187 Answers
Epson no longer supports the GT-7000.
I doubt that the Windows 7 drivers will be made available.Consider an Epson "WorkForce" scanner or all-in-one. WorkForce is the latest Epson product line.
Epson is the best!
Posted on Sep 28, 2009
I have a similar problem with the GT-7000 scanner interfaced with the Adaptec AHA 2910 SCSI PCI card in a 64 bit Win 7 pc. I have a program (Vuescan) which would operate the scanner but the scsi interface card cannot handle the 64bit data on the PCI bus and so the pc cannot 'see' the Adaptec card, nor the scanner. Adaptec do not support their card anymore, so my SCSI GT-7000 is scrap. Other manufacturers produce cards that would work but cost more than the scanner is worth.
Posted on May 08, 2010
Installation of Epson GT7000s (sameas Perfection 636s) under Windows 7 (32bit) I am posting this as I had enormousdifficulty in finding a route by which to install my much loved Epson GT 7000sSCSI scanner under Windows 7 (Home Premium). I will cover what did not work aswell as what did. The scanner was originally running quitehappily with an iWill 2930c card under Windows XP SP3 on my old PC. Changed PC toMedion MD 8339 with Windows 7 and theredid not, at first sight, seem to be any way of getting the scanner working. Epson'ssite indicates that the GT 7000s is not compatible without suggesting asolution. The GT-7000 does not appear on Epson's site as compatible with Win 7. It must be emphasised that my Windows 7O/S is 32 bit - I don't know whether this procedure will work for 64 bit. My original card was a clone ofAdaptec's which is no longer supported and clearly wouldn't do the job.Adaptec's website gave a number of cards that are compatible with Windows 7. Ichose the 29160N as this has the 50 pin external connecter which matches myexisting cables. Others may wish to chose one with a 68 pin external connector.Sourcedone on e-Bay for less than £5 delivered. Downloaded driver file (u160_w7_ws08r2_x86_drv_b7_5_645_100.exe ) from Adaptec site and unzipped it. Installedcard in free PCI slot - (did not connect cable at this stage). First (unsuccessful) method to try andinstall driver- Start -> Control Panel -> Hardware& Sound Under 'Devices and Printers', clicked'Device Manger'. Highlighted 'PC' (top of the 'tree' inlist - may show different description in another installation). Right click tobring up 'Hardware Wizard'. Click 'next'. Select 'Install hardware that Imanually select from a list'. Click 'next'. From the list that comes up select'Storage controllers'. Click 'next'. This is where I got stuck:- The only itemlisted under Adaptec is AIC-7870 PCI SCSI Controller (emulated) and not the29160N. Same result occurred when I got into theHardware wizard by using <winkey>+R and typing 'hdwwiz' into the 'Run' box. Adaptec were helpful, but ultimatelyunsuccessful, in trying to get the card to work. Discussion with them wasongoing when I tried the following, which didwork. I accessed' Device Manager' by:- Start-> Computer -> System Properties tab -> Device Manager. In the list there was an entry under 'otherdevices'. Highlighted this and right clicked. Select 'update driver software'. Highlighted'browse my computer for driver software'. At this point, the software installedand the 29160N showed up in 'storage controllers'. Connected cable and scanner. I used the driver which I had had on myprevious system (twain34.zip) and unzipped. I am not sure if this driver isstill available from the Epson site but it is still available at:- http://members.driverguide.com/driver/detail.php?driverid=11269 At the first attempt, a warning messagecame up saying 'General file transfer error. Please check location and tryagain. It identified a file in C\USERS\....\APPDATA\LOCAL\TEMP\TEMP1~4.ZIP\DRIVER\EPSCAN2\DATA.1 I located this and deleted (there wasonly a single .isu [uninstall] file), and tried again. This time it worked. At this point I had a fully working setup with one issue - each time I scanned, I got an error message saying 'Errorcreating directory'. Clicking on 'OK' removed the message and allowed the scan,but it came back the next time. I then went into the Epson Scan II properties(Start-> Epson Scan!II 32, right click, click on Properties, click on Compatibilitytab and check 'run in compatibility mode' with Windows XP SP3 in the drop downmenu. This solved the problem. I have since unchecked that box and the problemhas not returned. So don't throw away that GT-7000. It canwork under Windows 7 (at least 32 bit)
Posted on Feb 13, 2011
Benq Mirascan 4.00 won't find Benq 4300 scanner using Windows 7 32 bit
I think this scanner is not supported in Windows 7 OS. You can alternatevely try to install Virtual PC->Windows XP Mode and install your scanner there, so you could use your old hardware. If you want to follow my advise, go to this page and follow the instructions about downloading and installing Windows XP mode on your workstation.
Nov 23, 2011 | BenQ Office Equipment & Supplies
I need a driver for my epson 1200u photo scanner. my windows system is 64 bit, window 7. can you help?
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
Dec 09, 2010 | Epson Perfection 1200 Photo Flatbed...
Hello, my name is Dino palamenghi and I have an Epson Scanner GT 7000. Should I have the driver to instll it on windows 7? Thanks in advance. Sincerely yours, Dino Palamenghi
You should have the driver for this in Windows 7 by default if it works don't worry about it - if it doesn't work - look for it in driver and hardware - remove it and then reboot the pc. The pc will automatically find the printer sand seek out the Driver and install it.
Get back to me for more information and will follow up with you for the next few days if need be.
Gary @ Fix Ya
Nov 30, 2010 | Epson GT 7000 Flatbed Scanner
Looking for a driver for epson gt 7000 scanner for windows 7.thanks
I do not see this scanner on the Epson support site. They may not have a Win7 driver. You could try an XP driver in the compatability mode (right click on the driver and select Properties and the Compatability tab. Check the box next to Run in compatability mode) You can download a driver from a site like this one, http://download.cnet.com/EPSON-GT-7000/3000-2118_4-73143.html .
Another possibility is available in Win7 Pro and Ultimate. Download and install the XP mode from Microsoft. Install the scanner in the virtual XP computer. You may need to save files to external media to transfer them between the two computers.
I hope this helps.
Jan 31, 2010 | Epson GT 7000 Flatbed Scanner
How can I get my epson GT 700 scanner to work on windows XP
Once it is installed on Windows XP you can change the setting in properties to run Windows 98 compatible. It used to work with older scanners and printers. Try it out.
Dec 04, 2008 | Epson GT 7000 Flatbed Scanner
Epson GT 9000
i have scanner epson GT9000(ES 1200C) and lost the driver to runnig it , I did fomat to my pc now my scanner not function pleas if you can help me to povide me the scanner driver.
thanks
May 31, 2008 | Epson GT 9000 Flatbed Scanner
Epson GT5500 Flatbed scanner
unfortunately Epson has not made a driver for this scanner that is compatible with Vista and from the looks of it, they don't seem to have any plans on making one!
Sorry
Jan 29, 2008 | Epson GT 5500 Flatbed Scanner
Epson GT 7000 Flatbed Scanner Logo
6,608 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
