Question about Ryobi Saws
How to replace Ryobi circular saw CSB140LZ lower guard assembly
I have a Ryobi circular saw CSB140LZ that has a bent lower guard which the saw blade rubs against. I purchased a replacement lower guard assembly and cannot figure out how to get the old one off. There seems to be a retaining ring that rests in a groove on the spindle which prevents the guard from coming off. Doesn't appear to be a snap ring. I took the whole assembly off and tried from the back but couldn't see how parts separated. Any idea how to do this?
    Novelist:
  • 141 Answers
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Posted on Sep 28, 2009
Testimonial: "Got it. Thanks"
  • 5,603 Answers
Often these retaining rings have either a near-invisible gap OR they are more than 360 degrees around, sometimes going around twice.
If these are the type you have, one has to use a sharp intrument to catch and lift the end outward and uncoil the thing from the groove.
It can take patience...
Testimonial: "Thanks, I got it."
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
Why is my blade hitting the blade guard
Hard to say without seeing it but....wrong sized blade, bent blade, clamp missing or installed wrong, bent guard, or bent blade shaft. I'd look in that order. Hope that helps.
Jul 26, 2014 | Skilsaw 5150 Circular Saws
Ryobi TS-254 blade guard does not retract when blade is lowered
Probably something jammed up inside the body of the saw where the guard retracts, like a chip of wood. I once had the same problem with my circular saw guard not retracting. Turned out there was a screw that had somehow gotten trapped in there and once that was removed, guard functions perfectly now. Definitely sort it out as soon as possible because this is very dangerous--you could make a cut, rest the saw on your leg and... earn a quick trip to the emergency room.
Aug 11, 2011 | Ryobi Saws
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Circular saw blade rubs on the guard
remove the blade and check for the inner flange that should be behind blade. also there might be a ring underneath the inndr flange. or check to make sure the flange is installed correctly.
Apr 05, 2010 | Ryobi Saws
Ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Sep 28, 2009 | Ryobi P501 18v Circular Saw Only
How do I install the blade
you need to pull back the lower guard (remove battery first) and then start the blade at a slight angle until it goes into upper guard and then put on the spindle and reinstall the flange and blade bolt and tighten bolt till snug. You might try Ryobitools.com for a users manual or call them direct at 1-800-525-2579 and have them email a manual to you.
Sep 27, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
How do i change the circular saw blade on my saw? because i cant get the blade out to swap it as its blunt and the blade is now blunt
After removing the blade bolt and the outer flange you will need to fully retract the lower guard (remove battery) and sometimes wiggle the blade but it will come out.
Aug 29, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
I'm trying to figure out if I need to hold the lower blade guard up while the saw is running...there is no lock for it
No you do not need to holde the lower blade guard up. It should be spring loaded and move upward as it engages to piece being cut. depending on what you are cutting, you may need to hold it up to start the cut, but then it can be let back down while cutting. It is a safety feature designed to keep as much of the blade covered as possible during use.
Jun 27, 2009 | Ryobi 18v Cordless 5-1/2" Circular Saw...
Ryobi Circular Saw
unplug saw
new Ryobi have a spindle lock button, it is unobtrusive and you may miss it
739d802.gif If yours does not, secondhand etc, a screwdriver in the blade teeth between the upper and lower guards provides a locking bar enough to undo the arbor bolt
Jul 30, 2008 | Ryobi Multi-Volt Battery Charger
Saws Logo
508 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
