Question about BenQ Office Equipment & Supplies
Benq 6200 shuts down immediately
I had bulb burn out last weekend. Ordered and installed new bulb but now I get 2 red flasshing lights and 1 green solid light and then it shuts down. What should I be looking for?
  • 2,236 Answers
Did you reset the lamp timer? also may be the ballast.
Posted on Nov 12, 2009
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Wont power on
Sounds like you need a new bulb, or possibly new lamp. The red/green flashing is the warm up to get the bulb ready. If it's shutting down after that, instead of turning on, it means the bulb isn't working - that's a common thing, for the bulb to burn out. Possibly the lamp's bad, but that's much less likely.
Sep 01, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
New lamp won't light
I am having the same problem now. I am currently trying to reset the timer...but have yet to successfully. But I do think this is the solution.
Jun 10, 2009 | Sharp DT-100 Multimedia Projector
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Mar 16, 2008 | BenQ MP610 Multimedia Projector
802 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
