Question about Frigidaire GLTF2940ES Front Load Washer
The washer drum will not move, it is frozen, help!!!
  • rolando ingking May 11, 2010
    Is the power plug attached to the outlet?
  • 291 Answers
In most cases this is caused by the main bearing that holds the drum being siezed. If this is within warranty, it should be covered. If not, you'll need to tear the whole washer apart to replace it. Not a complicated job, but not for a novice. You'll need a service manual, but with that and average mechanical ability you can do the job on your own.
Hope this helps, but hopefully it's under warranty!
Posted on Sep 28, 2009
Ftf530es knocks during spin cycle
Good Afternoon Amy,
I understand that your Frigidaire washer, model# FTF530ES, knocks during the spin cycle. I also see that the drum moves from front to back and not up and down. I suggest making sure that your washer is level from front to back, side to side, and from corner to corner. If after leveling you washer, the drum is still moving from front to back, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why the drum is moving from front to back. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
Clothes are being shredded in washer
it sounds like you have a bent piece of metal round the drum you will have to make sure the drum is empty with your hand very slowly move it round the whole drum if you find it with a small hammer don't hit it heard OK just tap it till its not going to shred your cloths OK if you don't find any thing you will need to look at the paddle in the drum to make sure there not Brock or moving OK hope i can help
Oct 22, 2012 | Maytag Washing Machines
Washer is making a rapping noise on all cycles
The drum may have become damaged if it was moved without securing the drum.
Your washer probably came with drum "bolts" to hold it securely while moving it.
http://www.ehow.com/how_6731367_transport-front-load-washer.html
Mar 01, 2011 | Kenmore HE3T Washer
I have a ge washer model#wssh300g1ww. there is
You either have a bound up (frozen) drain pump, or knowing GE's reputation with washers, the transmission (gearcase) just dug it's own grave. How old is it? Depending on the age, it might have a frozen pulley.
Dec 16, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer tub won't spin. Belt is slipping. Drum seems frozen.
you might have a relay thats shot or the brake solenoid is shot. check both of those, it may fix your problem.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Maytag washer spin trouble drums moves from side to side
under the drum is a plastic support that can wear out. it must be replaced. if you do it yourself not too expensive
Apr 20, 2009 | Maytag Washing Machines
WASHER DOES NOT TURN
Sounds like the motor has frozen. Try to work the drum loose from the bottom (empty and unplugged) it just might be jammed from a pen or similar item lodged inside (someone not emptying their pockets). Since its buzzing (its the motor TRYING to move the drum) it has to be jammed from something. Rarely it could be a bearing locked up in either the drum or the motor itself though its unlikely.
Mar 21, 2009 | Washing Machines
Kenmore 80 series washer
drum is stationary in wash and moves only in spin
Aug 19, 2008 | Kenmore 24032\24036 Top Load Washer
Pav2200 model
Sounds like a transmission problem. It's locked in agitation mode. When it is in agitation mode you can't turn the drum or move the agitator. I'd check that out.
Jan 17, 2008 | Maytag PAV2300 Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
69 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
