Question about Cell Phones
My phone locked, I took the battery out to try and get it unlocked and now it will not come back on,please help
  • cartere91 Sep 28, 2009
    Thank you but it didn't really lock as far as code locking, it just wouldn't respond, so I took the battery out and now it will not come on at all. And it is a Verizon Chocolate VX8500. Thanks
  • 832 Answers
Your phone have an unlock code in your manual. If not
you can asked the service center of your brand and
unlock it. I cannot give you the code since you did not
provide us your phone brand and model.
Posted on Sep 28, 2009
My BMW Z3 I took the battery out now my doors will not lock or unlock but if I try to unlock door car will not start but if I disconnect the bat and put back and don't try doors it will start I need...
Put your key in the ignition switch it on and back off remove key no PRESS AND HOLD UNLOCK BUTTON without releasing the unlock button press the LOCK button 3 times within 10 seconds doors should lock and unlock rapidly to confirm it worked you must do this sitting in the car with doors and windows locked
Apr 07, 2014 | Cars & Trucks
Screen black and wont unlock thanks to Lock 2.0 I was using the phone trying to send a Facebook message and got impatient. Then the screen went black. Im using Lock 2.0, but the original lock on my Droid...
It can be fixed if you keep pressing the home button repeatedly. It will finally give you theoption to set your home default back to LauncherPro. If you wish to uninstall the Lock2.0 Hit Go to Menu Say Settings Once in Settings you can navigateto Applications and uninstall the Lock 2.0. Good Luck
Jul 13, 2011 | Android Apps
Hi I Cant Find A Free Sim Unlock Code For A Samsung Sgh J700i Could You Help Me?
1- Power on phone, type : *#7465625#
you will identify which code is active , which is inactive
2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your phone should restart after 1 min,
now, and before it restarts, push your sim card in, without removing battery.
4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now , Enjoy
6- now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
Dec 15, 2010 | Samsung J700 Cellular Phone
I have forget my security code of nokia N72 my imei no is 359726002105168.please anybody help me
try these:
You need 1 mobile phones and a memory card reader.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
memory card reader. Create
the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345".
Feb 10, 2009 | Nokia N72 Cellular Phone
How do you unlock a sansa m250 mp3 player
OK, I don't mean to be obvious, but on the bottom of the device (as you're looking at the screen), there's a switch that locks it. If you can see the red, it's locked -- if you slide it over, it unlocks. Again, you may have tried that, but since it says "Hold" and not "Lock" under the switch, it's not entirely obvious. Hope that helps?
Nov 18, 2008 | SanDisk Sansa m250 MP3 Player
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
Samsung e-250 i need unlock code
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
Jan 08, 2008 | Nokia 1600 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
