Question about HP Pavilion DV6700Z Notebook
Cannot access the internet
I cannot access the internet. I have a broadband service... just recently computer cannot connect to the internet.
I have contacted my internet provider...they say the problem is in the computer.
Sandy.
  • 1 more comment
  • Lewis Fulkerson
    Lewis Fulkerson May 11, 2010
    Are you connecting us your ethernet port or a USB port? Have you checked in the Control Panel to make sure your Ethernet and USB functions are working? Let me know if your use Ethernet or USB - which?
  • rahatfaraz May 11, 2010
    Solution chack on this site www.solve.tk
  • Amruth Louis May 11, 2010
    Have you configured the IP and DNS settings for the connection? Please detail your problem as much as possible. Is it a problem with the connection or do you frequently get 'Page could not be found' error?
  • 788 Answers
I have looked at and reviewed your problem with your HP laptop DV6700Z and have the fallowing for you to aces.
First, if you are trying to access the internet via wireless, wait until you have established and wired connection.
If the blue light comes on in the front panel, the wireless is working, if not, you have a problem with the wireless modem.
Run a wire from your laptop to your modem and enter your my network, choose setup a internet connection.
Try to make a internet connection. Once you have established a connection, you can setup your wireless connection.
Hope this has helped you.
Posted on Nov 05, 2009
How do I connect to broadband on modem/router
You may need to contact your internet provider to ensure the router you replaced your old one with is compatible with their service.
You may also need account information that must be put into the router manually. Your provider can tell you this as well. Sorry we can not be of more help in this matter. But Fixya and it's users have no access to your account details of any kind.
Oct 20, 2014 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
My mother recently got a zyxel wireless router, didnt realise that her computer had no wireless adapter so she went and got a portable wireless network adapter and installed it. Turned on the router but...
First you need to decide what type of broadband and Internet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Note - Combined services generally offer discount pricing and may include a modem/wireless router.
If you use a wireless router with the DSL or Cable Internet service then your laptop with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans.
Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD.
Jan 06, 2013 | Computers & Internet
My yahoo massanger can open but mail box cant
That is an indication that the computer device least has the entire space accommodating yahoo internet browsing also chatt messaging also known as texts simultaneuosly.
solutions to the conditons
1. the computer may have sufficient spaces to accomodate several programs yahoo chats, messagers. However, ascertain the computer network connection capacities been least inovative. For example, recent network connnections of broadband internet allows to text, video conference between devices. Prior ascertain that the computer is of recent innovation because attempting to sonsult with an internate agency of installing broadband connection may require that devices are recent compartible to produce desired effects.
Jul 22, 2011 | Yahoo Mail
My laptop is conecting but says limited or no connectivity but I have a strong wifi signal
Did a bit of research for you on this and came across a ten step set of instructions which should hopefully correct, or at least narrow down your problem:
Jan 04, 2011 | IBM ThinkPad X40 Notebook
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Cannot connect to internet
There could be many types of connecting to the Internet. Here are some types of Internet that you can connect to.
* Dial Up Connection
*Wireless Router or Access Point.
*Broadband
*Wireless (Recommend for Laptops)
*Ethernet (Recommend for Computer)
To connect to the Internet, try contacting your ISP (Internet Service Provider). If you haven't one so, then contact a Computer Technical Service.
Thank You for Using FixYa!
Oct 19, 2008 | HP Pavilion dv2000t Notebook
I having problems connecting a netgear 54 rt usb adp router to virgin broadband.Router is saying there is an internet connection but computer displays cannot display page and no connection.PS3 has picked...
on your computer try to reinstall the device driver for wireless. try to connect the ethernet cable directly to the computer. if you have internet access, then most likely your netgear router needs to be reconfigured. you need to contact your internet service provider or router manufacturer for the reconfiguration of your router. mostly likely the security settings of the router needs to be changed.
Sep 16, 2008 | Computers & Internet
Cannot Access Internet By Using Microsoft MN-500 Base Station
CAUSE This issue occurs if there is a problem with the domain name system (DNS) server settings on your network. RESOLUTION To resolve this issue, use the following procedures in the order presented. Determine if your DNS settings are the cause of the symptoms you are experiencing. To do this, following these steps: 1. Gather the Internet protocol (IP) settings from your computer. a. Click Start, click Run, type CMD, and then press ENTER. b. At the Command prompt, type ipconfig, and then press ENTER. c. Make a note of the information that is returned. You can copy and paste the output in another program, and then print it if you want. 2. Use the Ping.exe file to check your hardware. For additional information about how to use Ping.exe, click the following article number to view the article in the Microsoft Knowledge Base: 814155 (http://support.microsoft.com/kb/814155/EN-US/) MSBBN: How to Use Ping.exe to Check Your Microsoft Broadband Network Adapter 3. Bypass your Base Station, and connect your computer directly to your broadband modem. ? If you can access Internet Web sites as expected, the problem is most likely in the settings on your Base Station or on your computer. ? If you still cannot access the Internet, there may be a problem with your modem settings. Contact your ISP, or see the documentation that came with your broadband modem. If your network is functioning correctly internally, and you still cannot access Internet Web sites, there may be a problem with your DNS settings. To configure your DNS settings, you must know what the correct DNS settings are for your Internet Service Provider (ISP). See your ISP or the documentation that they provided when you signed up for service with them. To resolve this issue, following these steps: 1. Open the Microsoft Broadband Networking Utility (BNU), click Base Station Management Tool on the Tools menu, and then log into the Base Station Management Tool. 2. In the Base Station Management Tool, click Wide Area Network in the navigation list. 3. Select the appropriate type of Internet connection under Internet Connection Type, and then type the appropriate information.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
HP Pavilion DV6700Z Notebook Logo
409 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
