Question about KitchenAid KFCS22EVMS Stainless Steel Compact Wine Cooler Side by Side Bottom Freezer French Door
When I move the refrigerator is scratches my floor
When I pull the refrigerator out it scratches my floor. Is it set up wrong by the retailer who delivered it. All other refrigerators I have owned did not scratch my floor when I rolled them out.
    President:
  • 1,187 Answers
All refrigerators have wheels, including yours.
There are also two "leveling" screws with rubber pads next to the front rollers.
Turn them clockwise (normal screw) to raise the pads so that the refrigerator is free top move around. The levelers are probably not required, so raise them up high.
I suppose that 99% of all refrigerators have the levelers raised....
Posted on Sep 28, 2009
Brush roller works on carpet setting but not on floor setting. have already cleaned roller. suction is great. just won't do anything on floor setting (all 3 settings)
Check the arms that make the roller go up and down to achieve the settings. There may be something clogged in there.GOOD LUCK FRIEND
Sep 14, 2014 | Electrolux EL8807A Precision BrushRoll...
Is there a way to remove the drawer in the bottom freezer?
Pull the drawer all the way out until it stops. Then lift the front of the freezer drawer (a couple of inches), and pull out further (4-6"). The front will then lower to the floor. Lift the back of the drawer upward and slid the entire drawer forward. You may want to protect your floor. I did the above with the freezer drawer full and scratched my floor a little...
Jun 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a side by side and have decided I finally need to clean behind it....but it won't budge...I don't want to scratch my floor...are there locking wheels on it or am I just weak? lol!
The manual shows rollers but does not mention any locks. See page 4. Make sure the front is raised enough for the rollers to protrude below the frame. They are probably just stuck in place on the floor. You should be able to move the refrigerator out without scratching the floor if the rollers turn freely. Try some WD-40 on the axle pins if the rollers are not turning freely.
Mar 27, 2010 | Frigidaire PLHS39EES Stainless Steel Side...
How to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Sep 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
How do I replace the water line on my ice maker on a Dometic ndr 1292 refrigerator. Do I have to pull the refrigerator out and if so how can I get instructions to do so?
most refrigerators have fixed position wheels on the bottom rear, And leveling bolts at the front. Try to pull the unit toward you with a little force. If the unit does not move then you will have to lower the leveling bolts until the front wheels touch the floor.
Jul 18, 2009 | Dometic NDR 1292 Refrigerator
Loose door handle on 511 model
I assume it is a factory stainless steel handle. There are set screws on the floor side of the standoffs. If you look at the bottom of the stand of you will see a small whole about 3/16 in diameter, inside this is a set screw. I cannot remeber the exact size but it is pretty small. Be careful when you are tightening not to scratch the stainless finish.
Jan 03, 2009 | Sub-Zero Bottom Freezer Refrigerator
GE fridge, wheel locks
if is a ge there are no locks on wheels just try to be care full it should move easier when emptied and buy a scratch plastic the you can use when moving unit that is what we use every time and i am a sears tech
Oct 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Front leveling wheel broken-Can't move Fridge
go to good hardware shop of fridge retailer and there you will get small trolleys that you put the fridge on and then it rolls to where you want it
they come in a pack of 2 and fit under existing feet and rollers
Jun 06, 2017 | Refrigerators
Refrigerator slides on floor causing door to bind
there should be some adjustable feet in the front that you can tighten down so that the wheels get pushed off the floor. causing the fridge not to move. if that is already tightened down another idea is to find out the distance from the back wall and get a piece of wood that length and just set it back to prevent the fridge from moving back. hope that helps
Jun 11, 2008 | LG LFC25760 French Door Refrigerator
KitchenAid KFCS22EVMS Stainless Steel  Compact Wine Cooler Side by Side Bottom Freezer French Door Logo
416 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
