Question about RCA P52960 52" Rear Projection Television
Cost to repair an LCD tv screen
My 52in Sharp Aquos tv screen was hit with something and is damaged(appearance is similar to a broken mirror, with red and green lines all over half of the tv.) About how much is this going to cost to get fixed, is it even worth having repaired, or is it going to cost more than the tv is worth?
  • SD Tech
    SD Tech May 11, 2010
    if the panel is damaged, buy a new set--cost of part is more than set cost new
  • 2,318 Answers
In today's electronics devices there isn't much to repair specially if the screen is damage. The cost of the repair might exceed the price of the LCD. A cheaper way to get it fix is to try to find a defective LCD(same model) with intact screen.
Posted on Sep 28, 2009
Considering buying a used 46'' sharp aquos lcd tv/ mode # LC-46e77u, but the screen is cracked and now needing to know the cost of replacing the screen
Don't buy this tv.The tv LCD screen broken,the tv is junk now,not worth as a whole tv anymore.The replacement of the LCD screen,will cost the same as a new tv.The tv LCD screen panels are limited produced,by the tvs corporation.Will cost the same as a new tv,if require changing the LCD screen panel.
Sep 06, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How much will it take to fix a cracked membrane with vertical lines on it
Not worth fixing,if the LCD screen panel is damage or broken.Because LCD screen it limited produce it will cost the same as a new tv.Might even cost more after the LCD screen panel part and labors.The LCD screen panel is 90% of the tv,broken or damage LCD screen panel not worth as a whole tv anymore.The tv now only worth as salvage electronics boards parts.
Apr 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Wiimote hit my LCD. Looks like there are 3 layers - 2 are fine
You are most likely better off buying a new TV. You will need a replacement screen to fix the broken one but the cost of this can be almost as costly as a new TV so it is not economical
Nov 29, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Remote hit the TV and crakced LCD TV SCreen
There is no way you can fix a broken screen of a LCD set,the only way to fix it is by replacing the complete panel wich will cost more then a new set.
Aug 05, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My (sharp aquos lc 52d62u) tv fell to the ground. Image of broken glass and colored lines appear
Unfortunately the panel is cracked internally can't can't be repaired the whole panel has to be replaced. most times the panel will cost as much as you paid for the set. My son cracked ours when it was only 3 weeks old it doesn't take much force to ruin one.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp lc-46d64u broken screens
if the screen is broke its not worth the repair
Dec 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Broken bulb/liquid crystals in sharp aquos tv
The screen is damaged. This is the large LCD screen itself. You can bring the set to the factory service rep for an estimate. You will most likely find that the cost of servicing the set will probably exceed the cost of buying a new set.
Jerry G.
Jul 03, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 15 LCD TV
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
Apr 20, 2008 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
I have 2 flat panel TV's that don't work, one plasma, one lcd
Michael, my suggestion is that both units be scrapped. The plasma panel is broken the Dell and not cost effective to repair. If the inverter bds are missing in the Sharp, they were most pulled because the Sharp has a bad LCD panel. Not cost effective to fix either unit.
Feb 03, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Sharp Aquos 37 inch. Flat Panel cracked
try contacting these guys
the specialize in LCD parts
hope this helps
thanks for rating
Jan 09, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
RCA P52960 52" Rear Projection Television Logo
878 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
