Question about Canon PIXMA iP1800 InkJet Photo Printer
Printer feed The paper only feeds in on the right side and then all jams up.  I've looked to see if there is anything in there and can't see anything and I shook it upside down and nothing came out.  What should I do?
  • 4 more comments
  • Anonymous Dec 28, 2007
    Did you get a fix?
  • chefpearson Jan 10, 2008
    I am having the same problem also. Has anyone been able to fix this?
  • nylchq Feb 02, 2008
    Same problem
  • omgwtfbbqlol Feb 08, 2008
    same problem here, let us know wen you find a fix ^^
  • Anonymous Apr 15, 2009
    same problem!
  • mew56 May 15, 2009
    Me too!
I have the same problem!
Posted on Dec 30, 2007
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
Paper jams on right side when facing the printer
Please follow these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to t
May 01, 2009 | Office Equipment & Supplies
Paper is being pulled in on the right side and getting crumbled
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Clear paper jam light flashing
Please follow the instructions given :
Mar 20, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Printer 2480- my printer is pulling paper only on right side
Try this :
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
The printer says paperjam will not print out anything the paper allignment all to one side
Nov 06, 2008 | Lexmark Office Equipment & Supplies
Paper jamming in rx585
Oct 13, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
MY lexmark printers keeps giveng me an error that the machine is jammed or out of paper but is not the paper even has the tendency to catch and go down at an angle and this is not letting me print anything
Jul 16, 2008 | Lexmark Office Equipment & Supplies
Paper Jams
If this did not work check but type of paper are you using in the printer is normal printer paper , the replacement printer is refurbished onces they too have roller failure contact the company and make sure you get working printer..............
Jun 12, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
EPSON STYLUS PHOTO RX425, PAPER PROBLEM
disconnect the printer from the computer:
>manually feed paper using the paper feed button.
>observe, if the printer pulls only one side of the paper then it´s a hardware issue
Jan 01, 2008 | Office Equipment & Supplies
Canon PIXMA  iP1800 InkJet Photo Printer Logo
126 people viewed this question
old marine
old marine
