Question about Car Audio & Video
What size speakers are in a 2008 ford focus - Car Audio & Video
    Problem Solver:
  • 11 Answers
It is 4"
Posted on Oct 01, 2009
Car stereo wire diagram for 2008 Ford F1 50
I found this list for the 2008 F150
2008 Ford F150 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Light Green/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 08, 2017 | Ford Cars & Trucks
Tyre pressures for ford focus 2.0 ltr 2008 model?
Look either in the owners manual under the maintenance section or usually there is a sticker with the tire pressures for your car in the drivers door jamb. Here is an answer from another website where this question was answered:
Best Answer: That depends on trim level and tire size.
On most models with a P185/65R14 85T or P195/60R15 87T sized tire the recommended pressure is 32 psi front and rear, except the ZX3 which is 34/34 psi. On models with P205/50R16 86V sized tires use 34 psi front and rear. If you are not sure what you have check the Tire Load and Inflation sticker which you will see when you open the drivers door. It will tell you tire size and recommended inflation.
Mar 02, 2015 | 2008 Ford Focus 2.0
Image for valve timing for ford focus 2008 model
Why not buy a cheap shop manual, to give you all the information you need to tackle major repairs.
Aug 25, 2014 | 2008 Ford Focus
What is the location of the horn on a 2008 ford focus
the horn is on the lower passenger side on he chassis sub-frame in between bumper and front quarter panel
May 15, 2014 | 2008 Ford Focus
Bolt size for 2008 ford focus side mirror
Thread size is 8mm 10mm is the head size meaning you use a 10mm socket
Apr 01, 2013 | 2008 Ford Focus SE Sedan
2006 ford focus wiring diagrams
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
pls rate
Aug 21, 2010 | 2006 Ford Focus
I need the wire color codes for a 2008 ford focus, for the stereo! please help me!
OK HERE IS THE WIRING COLORS I SHOW, I WILL CAUTION U THAT THIS RADIO IS PART OF THE COMPUTER CONTROL SYSTEM OF THE DASH LIGHTING AND U CAN'T JUST PLUG ANY RADIO IN, CONTACT A CAR STEREO SHOP FOR COMPATABLE MODELS
2008 Ford Focus Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Gray/Orange & Violet/Orange (This vehicle uses the can data network for accessory turn on.)
Car Radio Ground Wire: Black/Blue
Car Radio Illumination Wire: Gray/Orange & Violet/Orange (This vehicle uses the can data network for illumination and dimmer controls.)
Car Stereo Antenna Trigger Wire: Black
Car Stereo Amp Trigger Wire: Violet/Red
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Apr 28, 2010 | Car Audio & Video
Connection/wiring dagram ford radio FCT006A2
2007 Ford Focus Car Stereo Wiring Diagram
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Oct 06, 2009 | CIBA Vision Ford Focus 2007 Stereo/radio...
I want to replace the mirrors on my 2008 ford focus so they can fold. can i buy those mirrors
The SVT has the folding mirrors. The size of the mirror itself is the same, you'd just need to check the connector and make sure it's the same. The parts department should know if they are the same.
Sep 28, 2009 | 2008 Ford Focus
Install a cd player
HERE YOU GO ALL WIRES U NEED PLEASE RATE ME GOOD LUCK WILL WORK GOOD!!!!!!!!
2003 Ford Focus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: None
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): White
Right Rear Speaker Wire (-): Gray
Aug 14, 2008 | 2003 Ford Focus
Car Audio & Video Logo
627 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
