Question about Kodak EASYSHARE Z1285 Digital Camera
Lens stuck out
I just had this problem also. I did the "tapping" thing and it worked. Thanks guys! (I have no idea why this happened tho) It is dissappointing as I really like Kodak cameras....
SOURCE: kodak easy share
the only thing that you can probably do i take it to somewhere where they can fix it. It is probably the only thing that will work. sorry. =/
Posted on Oct 01, 2008
praky16
  • 744 Answers
SOURCE: V1253 Kodak Lens stuck open, will not power on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.
Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Posted on Feb 12, 2009
t00nz
  • 4738 Answers
SOURCE: kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 05, 2009
  • 11967 Answers
SOURCE: Kodak camera lens stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 09, 2010
  • 11967 Answers
SOURCE: The lens on my Kodak m340 is stuck out and won't close.
Posted on Apr 23, 2010
Some how my Samsung SL820 digital camera's shutter door got stuck and it is not closing how many ever times I try to switch the camera off and on. Because of this the camera doesn't work. I've...
Did you happen to drop it accidentally? Or accidentally applied force into your camera? If yes, then there is big chance you will gonna have to replace the whole lens! If not, then it might just be dirt stuck inside your lens mechanism. To fix it, hold your camera with the lens facing the ground. Then, tap your camera repeatedly. Start with light tapping to moderate. If that doesn't work, spray condensed air directly into the lens part of your camera.
Sep 21, 2011 | Samsung SL820 Digital Camera
Lens error, does not go back in camera
usuall just get jams up most of the time it get stuck in tho its not commmon for it to get stuck out. i would just try to tap in gently against something. see if it dont free it up.
Mar 06, 2011 | Canon PowerShot SD3500 IS / IXUS 210...
My HK dvd101 player reports "disk error" with every disk
Hello Fixya Team,
I've focused in on the location of the problem. ATT, I'm trying to find a replacement input control board from Harmon. Not looking good tho. It acts like a cold solder joint or a flaky connector.
Thanks for getting back to me. If I end up stuck, I'll get back to you.
TKS,
BG
Jan 29, 2009 | Harman Kardon DVD 101 DVD Player
Samsung Digimax S600 is stucked in off position
I've had this with a diff model of Samsumg (V10). The problem with mine was that the lens wasn't opening, which was causing the beeping. I held the camera with lens facing down and when I pressed the power button I lightly tapped the camera against the palm of my other hand. The lens extracted.
I have more problems with the lens now but that may have something to do with me dropping it later:(
Aug 12, 2008 | Samsung Digimax S600 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Samsung L730 Lense Stuck Open...
Try tapping a corner of the camera on your palm 2-3 times..it usually works..
May 11, 2008 | Samsung Digimax L730 Digital Camera
Casio exz-650 lens problem
800-706-2534 and keep choosing option 2 and they will tell you where to send it. You can try resetting camera but doubt if that will help. Sounds like there was damage to the lens and that's why it's acting that way. Sorry for the bad news. :)
Feb 21, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens Stuck
Same problem guys!!! LENS HAD GOT STUCK - ABOUT ONE THIRD OUT after a knock. After lots of playing, and tapping and batteries in and out tried the whole twisting and pulling thing whilst turning off and on.
After a few minutes it came free and whole lens popped out. I then had to twist the outer part of the lens to straighten that up and allow it to fully retract. Works a treat now!
PS Tried the Sony online chat support - useless!!!!
Sep 08, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-W80
Ok, this is to all of you who had or will experience the same problem that I had as well. I found the simple solution that SONY should have tell us, but ... Never shake it!!!
Now get ready, is easy fast and reliable. Get WD40, a needle, a glass, tissue paper, a thin screw driver and a clean table. Now as you were to take a picture, at the left side of the camera you will find a pice were is written 3x optical zoom you will find a screw. Open ONLY this one and carefully remove the cap. Now, at the bottom, you will see a small black block with a **** with a tiny metal part in it. Ok, you are set to repare your camera. Lay the camera optic upward. Now use your glass to extract the WD40 with no mess, you just need a drop of it (well away from your camera)! Now dip the needle in the drop and apply the liquid on the tiny metal part in the ****. Repeat this once only just to make sure you have put enough lubricant. Now swich ON and OFF several time the camera until full recovery of the lent function. This work perfectly well and if you feel confident, add a drop on the elicoidal plastic groove, but no mess and clean any remain on the plastic as oil is going to run over time. Two half drop on the out lent caps could help as well. close the lid and your set for good years runing! Good luck. David
Aug 20, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
E18
This error is cause by a few things. First you need better power, how old is the unit? The battery pack may need replaced, the lens mechanism draws alot of power and sometimes if the flash is charging and the lenses are moving it struggles for power and shuts down. Another thing that can cause this error is jammed gears in the lens. This can be cause from an impact (dropped unit) or debris in the lens mechanism (sand, dirt, dust) the gears are so small and as is dust anything can blow in there and get jammed in the unit to jam it. I have got units to function again by tapping on the front of the lens while repeatedly tapping on the front of the lens. The idea is to work the jam out and free the lens. The E18 means a stuck lens but the reason its stuck i canot tell with out looking at it. Tap on the front of the lens (the part that moves in and out like a telescope) or try and tap on the side while powering it on. If you know some one with a unit like yours try their battery before you get a new one. They are very power hungry and if your unit is a few years old it may be time for a new battery.
Apr 03, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Kodak EASYSHARE Z1285 Digital Camera Logo
91 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
