IDL40 Not draining water off and 2 green lights fashing - what do we do?
    President:
  • 1,776 Answers
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump, like the occasional stray piece of clothing, and check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If any blades are broken/missing or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
Why does my kennmore smartwash elite keeps beeping and fashing f 02 signal
Your drain pump can't drain all the water, so your drain pump has a cap on it to clean out the filter. Clean the filter and try again, if this code comes back, replace the pump. Good Luck
Aug 17, 2014 | Washing Machines
Indesit idl40
Here is the manual
http://www.indesit.co.uk/indesit/_pdf/manuals/19504287203_UK.pdf
If you look at the trouble shooting page, flashing lights mean a clogged filter . If 2 flashes it needs to be turned off , and turned on again after five minutes. There is a call number -
Mar 20, 2014 | Dishwashers
Lights 1 and 2 flashing indesit IDL40
I used the solution above and my dishwasher now working!!! I would add, plenty of towels and a tray or three to catch the stinking water that comes out of the outfow when you tip it up. Yes 6 screws to remove the back, but on the Indesit IDL40 two additional longer screws in the centre are helpful to remove. Then just tuck the bit that was attached out of the way. My pump was cream and white - check out pumps online to see what they look like. Undo the one screw holding the pump in place and then you have to twist it to release three little pegs. I washed outs loads of small bits of grit. Then easy to put back together. Re-attach the drain pipe to your drain, electric plug at wall and water inflow pipe. (Check for leaks!) I am so happy! Took me two hours but I had to hunt for the info and find the hidden screwdrivers. Husband will be pleased I think.
Jan 11, 2014 | Indesit 18 in. D41 Slim-Line Free-standing...
Samsung frontload washer fashing nd code
The ND code means not draining
The older versions of this machine did not have a debre filter, but in later versions a drebe filter was added . It is on the bottom right of the front panel. Open the door. Pull the cap off the drain hose and drain water into pan. Remove filter cap. Wash filter off and don't block propeller when replacing filter cap. Insert cap back in drain tube.
Jun 04, 2011 | Samsung WF328AAW Front Load Washer
When i press the power on button the green light fashes
You should press the button for about three seconds. This is to ensure that you don't turn on the camera by accident (f. ex. in your bag or pocket)
Oct 25, 2009 | Hitachi Cameras
Hi, our Indesit IDL500 dishwasher has stopped working. The fault light 2 is flashing. The manual doesn't mention what fault this indicates. Any ideas. Cheers, Neil
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
Sep 26, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
