Question about Irons
Iron has light on so power is there however iron
Iron has light on so power is there however iron wont heat
    President:
  • 1,188 Answers
You will need to dismantle your iron. Follow the instructions below to locate the fault:
a. Make sure the power cord is not damaged.
b. Then, check the temperature selector. If it is in the correct position, something else is wrong.
c. Check the thermostat. As you disassemble the iron, clean the lint from the thermostat. Then test it with your ohmmeter. Set your ohmmeter on RX1 and clip the probes onto the terminal. Take a piece of wood or plastic and move the contacts open, then closed. When it closes you should see the ohmmeter just from high to zero. It so, it is working well.
d. Test the heating element. Do this by removing the base of the iron. There you should see the probes. Take you ohmmeter, set on RX1, and touch the probes. If it reads between 10 to 25 ohms, it is working correctly.
e. If you have an electronic iron, the only other possibility is the circuit board. If you have exhausted your options, take the iron to a professional.
Thank you.
Posted on Sep 28, 2009
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Wont turn on
see this steps and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Oct 01, 2012 | Irons
My Oreck Cordless iron stopped heating. The "Heating" light on the iron lights, but there is no heat.
Check and test this possible fault:
- Blown fuse
- Faulty or broken thermostat
- Broken power cords
- Broken heating elements
Hope helps.
Apr 20, 2011 | Oreck Cordless Speed JP8100CA Iron
On my iron all of the lights come, but iron wont heat up
Short answer is yes...but you would probably have issues with other appliances also if you had a power surge...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Nov 24, 2009 | Euro-Pro Shark GI490 Iron
Wont turn on
I agree.
It is probably a loose screw (if you shake the iron, you may hear it rattle).. The iron is most likely good, just needs a 5 minute repair.
If you want to do it, or find someone to do it:
1. UNPLUG the iron.
2. remove the 4 screws from the back end of the iron.
3. Open the back plastic plate.
4. There will be a wire with a loose screw; tighten it.
5. There may be a broken wire near the screw; if so, remove the eyelet that is on the screw. put the screw back on and wrap the broken wire end onto the screw and tighten.
6. Replace the back plate.
7. Plug back in and use for a few more years.
Hope this helps!
Sep 04, 2009 | Rowenta Power Duo Iron
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Apr 06, 2009 | Sunbeam Irons
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Shark G1490 doesn't light up or heat up when I plug it in.
circuit board has shorted out that control iron functions or power wire lead has broke off inside of iron
Jan 12, 2009 | Euro-Pro Shark GI490 Iron
I have the same problem with my black and decker iron. I will not buy orrecommend this iron to anyone.
Aug 09, 2007 | Sunbeam Safety Glide 3891 Iron
Irons Logo
304 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
