Question about Minolta QMS PagePro 9100 Laser Printer
Printer says media jam transport no jam found or bad switch that I can find
    Guru:
  • 389 Answers
Attentively examine the sensors of the passing of the paper. 1. The Sensor of the arrival of the paper. 2.датчик passings , he in medium device. 3. Datchih leaving the paper. Usually can be обрыванеи papers, or more often when paper извлкают damage the sensor and he comes out of its place. You should visual to make sure that sensor in its full tilt and есл no correct (it).
Posted on Sep 28, 2009
Media jam transport
Same as a paper jam. Media is paper. So check for paper also check that any acturators and or sensors in the paper path are ok.
Feb 15, 2013 | Minolta QMS PagePro 9100 Laser Printer
What is meant by e550 in toshiba E-studio 230?
Paper jam remaining in the copier when the power is turned on
Sep 21, 2011 | Toshiba e-Studio 232 Black and White...
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Paper jam to the right before printing starts
your paper must be jamming because your are not putting paper properly in the printer
Apr 01, 2011 | Canon PIXMA MX340 Wireless Office...
I have an Officejet J3608 model printer. its showing paper jam. But wen i checked i couldn find any paper jam in the printer. wat is the actual problem with my printer?
Perhaps the paper INDETECT SWITCH is faulty and so there is a false input to the CPU. You need to check this sensor/switch on the paper transport section where it is mounted.
Also check for loose connections on the main board, check for fault in the main board if the sensor seems to test correct.
Mar 30, 2011 | HP J3680 Officejet All In One Printer
What is a media jam and output tray is missing error? I could not find what these terms mean in the troubleshooting section.
Sounds like a little piece of paper is jammed on the rollers on top, or you have a bad sensor. Get in there and blow it out with compressed air or if it under warranty send it back.
Oh btw media jam (paper)and output tray(top part where paper comes out) is missing error (sensor is prob bad)
i hope this helps
Mar 01, 2011 | Samsung CLP-315W Laser Color Printer
Kyocera FS 9130DN is showing MP tray transport jam and to open front cover. No paper is jammed or in the machine.
check the bypass transport connector for a small piece of paper. or the paper sensor arm is jammed down there are 2 one in the transport unit and one in the mp tray
Nov 03, 2008 | Kyocera Office Equipment & Supplies
Samsung printer CLP300
Clean the rubber feeder belt with alcohol. Worked for me, Yesss!!!
Nov 03, 2008 | Samsung CLP-300N Laser Printer
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Minolta QMS PagePro 9100 Laser Printer Logo
438 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
