Question about Radio Communications
Where can i get a 19.655mhz crystal for an old cybernet ssb radio
  • 23 Answers
Http://www.bomarcrystal.com
http://www.golledge.com/docs/products/crystals.htm
Posted on Oct 09, 2009
I have a galaxy 88 and when u try to use it on ssb the radio will only do half power even with ssb power all the way up!
there is a ssb regulator bad or the power is turned down
this how to adjust ssb power output SSB ALC:
Mode to USB.
MIKE GAIN to maximum.
Inject two-tone audio signal of 500 Hz and 2400 Hz, 30 mV (-18 dBm) atMIC jack adjust VR12 Key TX; adjust for 25 watts PEP.
Sep 12, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Cannot select USB or SSB.Displays LSB or LISB? Very poor reception
On the Satellit 750 you have a button marked SSB. If you have selected a shortwave band then you can press the SSB button. Pressing the button repeatedly will toggle between LSB and USB.
You will need to know the exact frequency and the broadcast time, and the side band. Turn the radio on. Select a frequency which you know carries SSB signal and wait. Those that broadcast on SSB are not radio stations, maybe ham radio operators.
You can also select a short wave band, press the SSB button once or twice to select the side band and launch the automatic tuning system. It will scan the meter band and stop for a few second when it receives a strong enough signal. If you are able to perceive a clear signal on LSB or USB then you found a broadcaster. Some radios just have SSB and you cannot choose the side.
Personally, when I buy a radio I always insist on SSB but I have never been lucky tuning in an SSB signal. I keep trying once in while.
Jun 23, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Cybernet CB Radio does not receive or transmit. Switches on OK and lights up. ?? Can anyone advise how I can fix this ? (UK)
Several areas to check, Squelch should be all the way rotated to the left, Microphone may have a bad wire, bad audio amp.... Deeper problem could be a bad switching diode or bad relay if it is an older rig. Since the mic is the first thing to go bad, that is where you should focus...
Mar 20, 2010 | Radio Communications
SSB radio
If you are using the radio on a boat, then no, the grounding does not matter that much. However, an SSB transceiver would be hassle to install on a boat because of the amount of power they use to transmit. If the transmission is bad, try using the radio's internal tuner instead of the separate tuner. This may help improve the quality of transmit, however, some radios have a tough time clarifying incoming and outgoing signals and create a garbled sound when it receives a signal or when it transmits. If that doesn't work, then you can try grounding. But if you want a radio that doesn't require all this nonsense tning, you might want to think about investing in a Yaesu. They are pricey, but are one of the best HAM radios.
Sep 04, 2008 | Ranger TR-696F SSB CB Radio
Oscillating crystal
Solution: Replace crystal 1H00 with a new type, part number 823827736071.
Replace capacitors 2H08 and 2H09 with 4.7pF capacitors, part number 223886975478. See the attached photos for locations of the crystal and capacitors.
sorry the photos I have are in a PDF format and not supported here if you want send me an email and I could send the file
Jun 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
142 GTL Good AM Carrier Weak Modulation????
you may have to scope the finals circuit on the modulation to see if all the "inline" caps are installed correctly... be sure your pc board is grounded in all areas as required by specs in your manual. Make sure there is no bleedover and you are sheilding your crystals from the modulation platform. al
Mar 24, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
