Question about Dishwashers
I have a Cylinda 1443 De luxe dishwasher and I stopped and opened the machine while it was still washing. Now when I try to continue the program it doesn't start and all the lights are blinking. What's the problem?
  • 249 Answers
SOURCE: Kenmore 665 dishwasher washing light stays blinking
could be faulty outlet pump
Posted on Nov 28, 2007
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
SOURCE: Clean light keeps blinking and I can't start a new cycle
Clean blinking and nothing works
The solution works 100%
HI TEMP HEATED DRY
HI TEMP HEATED DRY
for ultra-wash quietguard3 Kenmore
Love you all of you
Posted on Feb 11, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Removing a built in Asea Skandia cylinda 1200
Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
Sep 30, 2009 | Dishwashers
Saeco Vienna De Luxe grinds but plugs up at door
Try this: clean out the chamber, then set the grinds coarser to see if it makes a difference. If it does not then the micro switch or solenoid that controls the door is broken. Check resistance on solenoid it may need to be replaced.
May 10, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Viena De Luxe ?
Hi Gadi,
Yes, if i would you i should repair the machine, that are a good machine.
When you replaced the boiler, make sure you descale it regulary then you will have many good espresso:-)
Best regards
/Mirran
Sep 04, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe (Trevi)
Hi Mike,
Try to open the steam knob to see if the pump is starting.
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna de luxe
Try to open the steam knob to see if the pump start.
Jul 04, 2008 | Saeco Vienna De Luxe Espresso Machine
User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Apr 25, 2008 | Dishwashers
Stops Mid Brew Cycle - Saeco Magic De Luxe
Hi
I would try to reprogram the button. Push and hold the button. Keep it held down while it is grinding. Don't release the button until you have the desired amount in your cup for that button. When you do, Then release the button. See if that doesn't clear the problem.
Apr 05, 2008 | Saeco Magic De Luxe Espresso Machine
Dishwashers Logo
102 people viewed this question
Top Dishwashers Experts
