Question about ASUS Computers & Internet
Failed to unlock Hard Disk!" - ASUS Computers & Internet
Failed to unlock hard disk
Posted on Oct 19, 2009
Forgot password hdd is locked
Unlock and Recover Hard Drive Password with Hard Disk ...
www.geckoandfly.com > Tutorials > Password and Recovery
Nov 18, 2015 - Is there any software to recover hard drive disk password? ... HDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. ... HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard ...
Unlocking a locked hard disk (lost password) - Straight ...
Dec 02, 2015 | Lenovo IdeaPad S10-3 Netbook
What does a biohd-2 message mean?
That error code means that your hard disk has failed. You can use the hard disk diagnostic test in BIOS for further confirmation. If either short or long test does not pass or causes your PC to reboot, the hard disk must be replaced
Unfortunately the normal solution for this is:
Locate your Recovery disc set or usb recovery media. I hope you took the time to make it.( your HP software asked you to do this)
Purchase a new SATA2 hard disk of equal (500 GB) or greater size. Remove the failed disk and install the new one.
Follow the instructions here and restore your original operating system to the new hard disk.
May 25, 2014 | Computers & Internet
Unlocking hard disk failed
use the diagnostic sofware coming from your computer and fix it.or you can go to web site to the Samsung http://www.samsung.com/us/support/ and see many tools software they have for fix many problem, or chat with the supportHowever you can try to Restore the computer to some date was working beforeUse the scan disk software and see what happen, and use the fix the archive too, in the properties of disk.God bless you
Jan 29, 2013 | Samsung Series 5 NP540U3C-A01UB 13.3"...
Hard disk 1 (3f1) error on HP pavillion dm1 series
So, can you see it in My Computer? If yes, get your data off the drive and format it!
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked.
If needed,you can download it and scan your hard drive for free to preview whether your files can be recovered.Get it from http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Apr 21, 2012 | Computers & Internet
BAD DISK BECAUSE PASSWORD LOUCK
Issue How to lock / unlock the hard disk drive.
Cause
A hard disk drive may be come locked or unlocked allowing or not allowing for software to have direct disk access. You may encounter an error indicating to unlock the hard disk drive in any of the below circumstances.
  1. Attempting to install another operating system.
  2. Attempting to fdisk the hard drive.
  3. Installing software.
Solutions
To unlock the hard disk drive
unlock x:
The x represents the letter of the hard disk drive that you wish to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
Additional information about the lock and unlock command can be found on our Lock / Unlock page.
To lock the hard disk drive
lock x:
The x represents the letter of the hard disk drive that you wish to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jun 16, 2011 | HP Computers & Internet
How to unlock the hdd password
I have a problem with my laptop hard disk.
the hard disk so I locked my laptop not open.
I tried to reinstall it can not.
I ask you a solution how to solve this problem. thank you
Jan 23, 2011 | Dell Vostro 1710 Laptop
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
My wd3200me was working now not
Try connecting to a different USB port on your computer.
Try a different USB cable.
Try connecting it to a different computer.
If it still does not work, either:
* the USB-to-disk-drive adapter has failed
* the disk-drive has failed
If the former, open the case, and remove the disk-drive,
and temporarily connect this "internal" disk-drive as a "slave" disk-drive into any desktop computer, and copy all the files. Or, remove the disk-drive, buy a new "empty" external-adapter, and install your disk-drive into the new case.
If all else fails, search online for "Data Recovery Services".
These type of companies are expensive, but they can "recover" files from almost any hard-drive that has "failed".
Jan 02, 2010 | Western Digital Elements powered by WD 320...
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My westerndigital passport size hard disk of size 320gb when connected to system at starting 2 to 3 beep sounds i am hearing and the hard disk is not detecting what to do? naresh
Either the USB-to-disk-drive adapter inside the casing has failed,
or your USB port has failed,
or the disk-drive inside the casing has failed.
Try a different USB port. Try a different computer.
Disassemble the casing, and remove the disk-drive.
Temporarily attach it as a "slave" drive in a desktop computer,
and see if the drive is detected, and if the files are OK.
If all else fails, and the Passport is still under warranty, exercise the warranty.
Apr 15, 2009 | Western Digital Passport 320GB External...
Computers & Internet Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
