Question about Lexmark X2470 All-In-One InkJet Printer
I'm looking for a part, it is the cartridge lever. It is the part you push to release the part that lay's over the ink cartridge itself.
    Guru:
  • 389 Answers
Reconstruction картриджа 13400НС (black) from jet printer Lexmark
The Jet printers Lexmark: problems with qualityof print. Many model jet printer Lexmark is used cartridge 13400НС Black (black). As beside all jet printer, seasonly appear the problems with quality of the seal - for instance, under long printer idle time, under faulty or wrong leading-in cartridge. For reconstruction of capacity to work cartridge recommend to use this methods.
First we shall consider the design most cartridge. She it is enough forgive;pardon: this capacity, in which is found поролон, and block termo heads all this is united in one integer. The Ink засыхают both in most porplone, and in block termo head.
The Jet printer Lexmark If ink засохли in block termo head not powerfully and not much загустели, that possible, using special liquid, wash ("overpunch") sniffled, not analysing cartridge. The Methods much forgive;pardon: in small capacity we fill the liquid for recovering (the composition to liquids, her(its) mark and type - a subject of the separate talk, for instance, here). Then medical syringe with put on instead of needle by rubber (refer to fig. on the right) through compensation hole create inwardly cartridge surplus pressure. The Ink from porolone result through sniffled the термоголовки and restore capacity to work cartridge.
The Jet printers Lexmark: problems with quality print If this has not occurred, signifies, ink much powerfully засоли (both in поролоне, and in термоголове), that come to restore картридж with full stripping. cartridge understands it is enough easy, only do this it is necessary neatly.
The Ithaca, scalpel separate the upper lid from most capacity, shall get porolone and wash in warm soapy water. While dries поролон, wash itself cartridge from the remainder of the ink.I'm looking for a part, it is the cartridge lever. - 13ab587.jpg
As it is seen on photo on the left, between block термоголовок and поролоном is found capacity with filter. Here is this capacity and it is necessary to wash from the remainder of the ink. For this possible use both special liquid, and become warm soapy water..53530cd.jpg
With the help of medical syringe with rubber adjutage we wash, clean картридж. Then all carefully dry (particularly if water was used). When all высохло, collect. At assembly pay attention to reliable contact porolone with filter.
Leading-in Stick the upper lid, beforehand having done заправочное hole, which comfortable do under letter "M" in word "LEXMARK". We Wait, as requested on glue, when he silt. We Fill porolone ink (refer to fig. on the right) i.e. we fuel cartridge. We Stick the orifice hole. And having created, again prepared syringe, in картридже surplus pressure, waI'm looking for a part, it is the cartridge lever. - 62df85e.jpgom sniffled appear the ink.
All - now possible print, long and qualitative.
Posted on Sep 28, 2009
Ink cartridge stuck printer
The manual says: To remove the cartridge, push up on the Cartridge-release tab then pull out the cartridge. It looks like a green lever to me, you have to push.
Nov 27, 2013 | Kodak Easyshare G600 (1633379) Dock /...
Ink release lever in brother MFC-6490cw broke
Did you ever resolve issue with broken tab. I have same problem on my black cartridge release tab, and am wondering if I can need tab or can salvage. Thanks!
Nov 17, 2012 | Brother MFC 6490CW InkJet Printer
How do u change ink cart
The process of changing ink cartridges varies slightly by the make and model of your printer. Open the cover to the area where your cartridges are installed while your printer is turned on. If opening the cover automatically prompts the inks cartridges to move and center in a position where they are accessible, then all you have to do is remove and reinstall new ones. If the cartridges do not automatically move and center themselves where they can be changed, then your printer requires an additional command that you do manually to make this happen. Some printers require the user to push the power button down and hold it for 10 seconds to have the machine move and center the cartridges in a position that can be reached easily by your fingers. Some even have an extra button to push that has a little picture of an ink drop next to it which brings the cartridges forward for replacement. If you cannot reach the cartridges easily, or opening the cover does not automatically move and center them then check your manual for the procedure or repost your question inlcuding the make and model number so that we can locate this information for you.
Lets move forward.
Once the cartridges are in an area that is easily reachable, the next step is to eject the cartridge which needs to be changed. This procedure can also vary by make and model. Look at your cartridges and check for a plastic ejection lever in front that can be pushed down by a finger tip. If you see one, push downward and see if the cartridges is ejected outward towards you. If it is ejected, then replace with new cartridge and push downward to lock it into place and your done. If there is no plastic ejection lever in front of the carriage which holds your cartridges, then place one finger on top of the cartridge you wish to remove and push downward slightly and pull it towards you until it unlocks and releases it. Then remove and replace and push down and forward to lock the new one by into place and your done.
I can give you specific instructions pertaining to your make and model printer if you supply this information on the website. Good luck!
Oct 26, 2010 | Office Equipment & Supplies
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
How do you change the ink
See the following URL for diagrams: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002072/Mini3_Mfc_Base_UsaEngUsr_B.pdf
Open the ink cartridge cover, on the front right side. Pull the lock release lever down and take out the empty cartridge (it has a little ink left). Now open the bag containing the new cartridge and take out the cartridge. Take off the protective yellow cover and make sure you do not touch the area that was covered. Push the new cartridge into place; there is an arrow on the side that indicates the direction in which it goes into the printer. Lift up the lock release levers until each one clicks (as needed depending on the number you unlocked before). Close the ink cartridge cover and answer the queries about the new ink to clear the counter. The counter will be automatically reset if you wait to see Near Empty and Ink Empty on the LCD screen before you change the ink.
If the LCD screen still reads Install, check that the cartridges are fully seated in their slots.
I hope this helps.
Jan 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
How to change the ink cartridge
With the power turned on, do the following:
  1. Open the ink cartridge cover (the carriage should move to the right to access if not already there
  2. Pull the lock release levers down
  3. Remove the old cartridge
  4. Remove protective tape from new cartridge
  5. Insert new cartridge
  6. Move lock release levers back up
  7. Close cartridge door (you may hear the carriage move back to the ready position.
That is the procedure for changing an ink cartridge. Thank you for using Fixya and please remember to return to rate the answer you've just been provided.
Greg
Nov 16, 2009 | Brother IntelliFax-2480C Fax
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
I need assistance changng the black ink cartridge on my MFC 24OC brother
  1. I have this printer myself.
  2. Facing the printer, look on the far right corner.
  3. You will see a little door below the scanner. This is where the single black and three color cartridges reside.
  4. Open the door and see the cartridges.
  5. The black will be the one that is to the far left in this compartment.
  6. Each cartridge is secured by a blue vertical "lever"
  7. Push on the blue lever and it should click and pop out slightly.
  8. With your index finger, pull down on the lever and the cartridge should pop out even further.
  9. Let the blue lever drop down and grasp the cartridge and pull toward you. The cartridge should come out.
  10. Remove the cover and tape from the new cartridge and put in the black cartridge slot until seated in the slot.
  11. Gently lift the blue lever until it clicks
  12. Close the door and the printer will begin to clean itself automatically.
If my assistance has helped you, please complete the rating. Thanks for using Fixya.com
Jan 27, 2009 | Brother Multi-Function Center MFC-240C...
Where is the ink cartridge?
It is on the FRONT RIGHT PANEL, See below. Bud
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in. If the display continues to show NO CARTRIDGE, continue to Step 2.
  2. Open the ink cartridge cover. Pull the lock release levers down and take out the ink cartridges.
  1. Reinstall the ink cartridges and lift and push each lock release lever until it clicks, then close the ink cartridge cover.
Jan 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
