Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Refrigerator is staying at 50 degrees, will not get any cooler
    Scholar:
  • 103 Answers
Check for frost build up on rear inside wall of freezer, if no frost, then you may have a damper control (located in top left rear portion of frig) stuck in the partially closed position. Another prob could be thermistors on frig side are defective. I would suspect damper first. Open refrig door, stick your hand up in front of "vent" looking are on top left side, see if you feel air, then push in on light switch with your hand and with other hand while hold light switch see if you have more air coming thru when you push light switch. If not I would suspect damper assembly.
Posted on Oct 10, 2009
  • 3 Answers
May be your computer board, not turning on the defrost heaters in the freezer section. The freezer will eventually get warm too. Are you getting frost build-up on the rear wall of the freezer? If you are, you can temporarily solve the problem by turning off the whole refrige for a day and open up the freezer door- put towels on the floor under the freezer doors. Then turn it back on - mine worked fine again. I am currently waiting for a computer board replacement. It is behind the metal plate on the back (outside) of the cabinet. Good luck.
Posted on Sep 30, 2009
My danby wine cooler does not get cold enough
Cool enough? You know most wine and beer only like it about 50 degrees and not any cooler. If it up at 55 and you have set it lower then the room is probably warmer then it can handle to cool them. I have some in the garage but in July and August the struggle to stay any cooler then 55 but then they are not expensive units either. Danby is cheap brand too. Nothing they make is that great.
Oct 07, 2014 | Danby Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Edgestar cwr300sz
This cooler's operating range is 40-65 F. If it is still in warranty contact the manufacturer. You could have a faulty thermostat. If so have it replaced.
Dec 30, 2013 | EdgeStar BWC120SS (36 cu ft) Wine Cooler...
Cooler wavers between 35 and 45 degrees.....even after turning the controls to colder. Would this be the thermostat?
Probably... OK I am going to fill you in on something here that almost no one knows. The True coolers all use a thermostat that reads the coil temperature and has no idea what the box air temperature might be. They are all pretty much the same but have a few different variations. For most beverage coolers though they are getting the coil down to around 13-15 degrees and then shut off and stay off until the coil gets back up to 38-40 degrees.This means that the air temperature can be anywhere from 23 to 50 degrees at any given moment but the product temperature is going to average out in the middle. If the box is full no problem the temperature swing will not be anything like this because the product will keep the temperature more stable. If the box is empty you will need to put SOMETHING in there to help stabilize the temperature before panicking. 3 or 4 gallons of water will do. Also if you want to sleep better at night put a thermometer in a glass of water in the cooler to get a better idea what your product temperature really is and don't put too much faith in the cheap dial thermometer mounted to the outside of the box. Oh and set the dial on 5 and if that doesn't work the thermostat could be a problem... they are the weak link in these units.
Aug 28, 2013 | True T23 Refrigerator
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
Avanti N252BG beverage cooler does not get cold enough
Brand new installed avanti beverage cooler. In a basement undercounter so room temp. around 65 degrees. Only gets to around 45 degrees inside even though temp is set to 34 degrees. Most of the time it sits for days without being opened but still not cold. Any suggestions on how to fix this problem?
Mar 26, 2009 | Avanti N252BG Beverage Cooler
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
251 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
