Question about Nintendo DS Lite Console
Left hand side of screen when touched dosnt work but right side does.its like its out of sink,right side works fine but left side when touch presses the right side as well,
  • 3 Answers
Hi inside the Ds the ribbon cable for the touch screen is loose, if you jarred the unit the lock that holds the cable in place popped open causing some of the wires to no longer be in contact. Open the bottom case half and look to the left of the slot 1 and make sure this cable is seated and the lock is closed.
Posted on Oct 10, 2009
  • 80 Answers
If you haven't tried calibrating it yet then i would just send it in to get fixed.
Posted on Oct 03, 2009
  • 81 Answers
Take it to nintendo
Posted on Sep 29, 2009
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Feb 07, 2014 | Minolta bizhub 200 Copier
I have a samsung genio touch how do i access the keypad during a call
On the right hand side of the phone, in just about the middle, is the button that's used to lock the phone.
When you make a call, once the ringing tone can be heard, press this button and hold it in until the screen changes.
One of the options on the new screen will be keypad (bottom left). Another option will be loudspeaker.
Hope this helps.
Apr 02, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
Phone sceen turns on. fully charged. touch screen works. Phone doesn't turn on. Phone off displays after I have touched the on/off switch.
With the phone screen showing, press the red button at the right-hand side and hold it for about two seconds. The Centro should display a "Welcome" screen, then after a few seconds the phone screen should reappear with the carrier name at the upper left instead of "Phone Off". Each time you press and hold the red button the phone switch on/off..
Oct 26, 2009 | Palm Treo 500 Centro
Touch screen letters inop on right side. Also when I try to scroll on left side it selects a street instead.
try to calabrate the touch screen if it dosnt work replace the touch screen part# CSX1085
Jul 22, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
My phone's(htc touch diamond)ringing volume is too low... i can barely her it ring in my pocket
there are 2 buttons on the left hand side of the phone. press the top button to increas the volume...
there are 2 volumes you can adjust, the system volume and the ring volume. you may have to touch the "Ring" tab on the top right hand side of the screen to adjust the ring volume
Jul 08, 2009 | HTC Touch Diamond Smartphone
Touch screen - left hand side does not work
this sometimes happends if you have knocked the screen a few times.
it also does this when there is water inside it i would recommedn you place it on your heater for 2 hours.
if there is a chip in the screen or the left hand side of the screen is smashed it will not work because the sensors will be damaged
Apr 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Archos 604 wifi touch screen out of wak
I think you can use the keys ...
Boot up
Press the <> button on the left hand side of the menu key
Use the arrow keys to get to display, press ok
Scroll down to calibration, press ok
PK
Jan 08, 2009 | Archos 604 WiFi Digital Media Player
I turn off the flash on my sony dsc - t77 , how to turn it on? i could not find the function!
That solution does not work on the T77.
I have the same problem and this is how I solved it.
Press the Menu button on the bottom left corner of the screen.
Go to the second page (2/3) select the "REC MODE" (it is the firrst choice)
Select your mode as normal and not burst and then exit the menu.
Now you should be able to activate the flash from the screen..
Hope it works for you as it did for me.
Dec 27, 2008 | Sony Cyber-shot DSC-T77 Digital Camera
Nintendo DS Lite Console Logo
150 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
