Question about Saeco Royal Professional Espresso Machine
Continually have message saying dreg drawer is missing but dreg drawer is in place
    President:
  • 1,618 Answers
Remove drawer and clean coffee grounds behind it, there might be something keeping it from reaching the microswitch.
Posted on Sep 29, 2009
I have a message that reads Dregdrawer full but it is empty
the machine is counting how many coffee is made,and then it's showing that dreg drawer is full. If you empty it before the machine showing that's full -machine don't know that you are empty it.Now you have to remove dreg drawer for 10 seconds and then put it back!
Oct 03, 2014 | Saeco Coffee Makers & Espresso Machines
Machine shows message 'dregdrawer full' even thought the dreg drawer is empty. cant get rid of this error message.
Hi
When you go to empty the dredge drawer you must leave the machine on. When you remove the dredge drawer it will say dredge drawer missing. Leave it out at least 15 seconds so the machine knows you are empting it. When you insert it again the machine will count about 24 cycles and tell you to empty it again. Its a counter.
May 12, 2011 | Gaggia Syncrony Compact Digital Espresso...
Emtied the dreg drawer when the SAECO machine was off.
Chenk the back of the area for the drawer, there might be some grounds preventing the draw from going all the way in to tell the microswitch that it is in place.
Jan 24, 2010 | Gaggia Syncrony Espresso Machine
The dregs drawer missing indicator on, unit won't work.
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
There is a micro switch whit an arm the hangs down in the slot on the side of the machine. Make sure that you have the arm for the micro switch.
Jan 11, 2010 | Saeco Magic De Luxe Espresso Machine
I have emptied the dregs drawer, after prompting, and I keep getting a message saying firstly that the dreg drawer is missing (It isn't and I have checked that has been properly fitted)and then that the...
Hi
When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic number for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn’t know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds
Dec 29, 2009 | Gaggia Syncrony Espresso Machine
I keep getting a message that says dreg drawer missing what is this? is this where the cup sits when it is getting filled? coz i have taken it out and put it back hundreds of times
The dreg draw is the little draw where the coffee pucks are released to after they've been use.
Typically if this message stays on even though the draw is in place indicates a bad microswitch.
doesn't cost much to get fixed, but i would take it in to a service center as it is a little rough to get to.
Jul 06, 2009 | Saeco Magic Comfort Plus Espresso Machine
Dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
Apr 10, 2009 | Saeco Royal Professional Espresso Machine
Dregdrawer Full
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Nov 19, 2008 | Saeco Royal Digital Plus Coffee...
Dregdrawer full message will not go away
Have you tried removing the drawer with the machine on, leave it out for say 2 minutes and then replacing the dreg drawer again?
There is no dreg sensor. Dreg drawer full works off a counter - depending on when the counter was last reset your drawer may be full but it may be empty.
Simply removing the dreg drawer and replacing it quickly will not reset it. The machine has to think that you have actually taken the time to empty it - a couple of minutes should cover this.
If this does not resolve the issue, you need to get a Technician to take a look.
I hope this helps
Aug 26, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Bought new machine yesterday.says ventilate which i did,then jumps to dregs drawer full,which is empty and clean what can i do now?
Are you still having the ventilate sign come on? If so, let hot water run out for 10-15 sec.
On the dregs drawer full message- carefully put back the dump box -making sure it slides in right. This happened to me the first time until I figured it out how to carefully put it back. If it is not in all the way, it will keep giving you that message.
Jun 16, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Professional Espresso Machine Logo
325 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
