Question about Gigabyte GA-7VM400AM Motherboard
Drivers hi again i have a GA-7VM400AM(F)motherboard , i am putting in 2 hdd for sata ,before i can install the 2hdd i need the driver cd motherboard can u help me in the right direction plz and the other thing is i also have a pioneer dvd-rw dvd 106d,it burns cd's but when i play a dvd ,it say's i have no decoder ,can u help me with this too ,again ty to for all you'r help regards Mark Scotland
  • Gigabyte Master
  • 3,287 Answers
Download drivers for your motherboard here:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1748
and
Download a free codec pack for DVD playback in Windows here:
http://www.codecguide.com/download_kl.htm
Posted on Sep 28, 2009
Testimonial: "again thank you to all the team that help, its a great site .mark from scotland"
How can I use a SATA HDD in a 7NF-RZ motherboard? What cables/adapters are required?
Hey there. To install SATA devices on any motherboard follow these steps:
1- Make sure your Motherboard supports SATA, a 7NF-RZ works fine.
2- Install the HDD on your case, usually you have to screw it in or if you have a newer case you can lock it in place with a latch.(The SATA slots on a case are usually above the optical drive slots).
3-If you have another HDD already installed, and you don't want the new HDD to have system files, make sure it's designation is set to Slave. To do this, remove the jumper on the HDD pins(a white plastic connector) with tweezers, and, according to your HDD specifications, move it up or down to Slave designation.
4-Use a SATA cable from your Power Supply and connect it to the HDD, then, use a SATA adaptor cable which should have come with your HDD and connect it to the HDD, then to your Motherboard SATA adaptor(these vary from motherboard to another, so use your Manual to specify where it is).
5-Boot up your computer, and enter BIOS. Usually press either F2,F5,F12 or Esc. After that go to Auto-Detect drivers. When you're done, Save & Exit.
You should have successfully installed your new HDD!
Aug 21, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
Sata driver for Samsung harddisk
You need driver SATA controller that is used on your motherboard. You need to find CD or download from internet, drivers for your SATA controller that is used by your motherboard. Put this *.inf files on bootable Floppy diskette. In Windows XP setup press F6, when it askes you. If you found correct driver you will see your HDD in setup.
Apr 16, 2010 | Computers & Internet
My Gigabyte GA-MA785gm-US2H does not recognize my Samsung SATA hard drive. I can see that it exists in the Advanced Bios Features, in the Hard Disk Boot Priority, and nowhere else. I can not load Windoews...
If you are trying to install Windows XP then this is to be expected. WIndows XP doesnt have native support for SATA. You will need to identify the SATA driver you need, then put that driver on a floppy disk. DUring the install of XP it will ask if you have any drivers you want to install. CHoose yes and put the floppy disk with the drivers on it in the disk drive.
If you dont have a floppy drive then you will need to create an install disk with the SATA drivers on it.
Jan 24, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
GA-7vm400am f sound card doesn't work
hi,
please try to install the drivers forcefully.
right click>exclamation mark>update driver>install manually>dont connect the internet>select from specific location>sound and game controller>have disk and then give the path where driver file is saved.
thanks.
May 28, 2009 | Gigabyte GA-7VM400AM Motherboard
I have a gigbyte GA-MA790XT-UD4P mother board that when I try to install XP on a new Seagate 1TB Barracuda HDD, that it won't recognize during the install process
If your hdd is sata and you have an old mobo , windows xp (onlycvista will) will not recognize it. Integrate sata in xp (use nliteand goolgle how to) or use the flloopy disk to run sata driver
Mar 29, 2009 | Gigabyte GA-K8VM800M Motherboard
Gigabyte K8vm800M Motherboard Does Not Recognise Seagate SATA HDD
I HAVE THE SAME PROBLEM IN THE PAST. I REPLACE THE IDE HDD WITH SATA AND AFTER I BOOT IT SAYS NO HARDDISK. IT IS BECAUSE WINDOWS XP HAS NO BUILT IN SATA DRIVER.
WHAT YOU SHOULD DO IS CHANGE YOUR HARDDISK TO IDE OR INTEGRATE A SATA DRIVER INTO YOUR XP (USE NLITE) OR USE THE FLOPPY DRIVE TO RUN SATA DRIVER ITS INCLUDED IN THE MOBO WHEN BUYING.
Mar 16, 2009 | Gigabyte GA-K8VM800M Motherboard
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
My motherboard can;t detect my harddisk.....
Hi modjoguy, the bios must see your SATA hard disk before windows can see your SATA hard disk drive. To check this please press the delete key every two seconds as soon as you power on the system. (Note 1: Some motherboards that do not show the SATA II drive while in the bios may need its jumper set to SATA I in order for the bios to see the SATA drive). (See the drives large white sticker on the hard disk drive for SATA I location of jumper).
(Note 2: Gigabyte GA-K8VM800M rev 2.x & Gigabyte GA-K8VM800M-RH motherboards use the same manual). The Gigabyte GA-K8VM800M rev 1.x manual is slightly different, thus page numbers differ from the other two above.
Here is the link for all three: http://www.giga-byte.com/Search/Search_List.aspx?Keyword=K8VM800M&SearchType=Spec
The bios main menu will open. Open your manual (rev2.0 & RH) to page 38 & read under the listing, "IDE Channel 2/3 Master". The idea is your SATA drives should be listed at 2/3.
Once they are seen you need to open Advanced BIOS Features page 40. You can load the advanced bios features by pressing "Ctrl+F1" keys. You must list the SATA drive you want as the primary hard disk drive (Usually its the model number of the drive), that will have windows installed on it.
Good luck modjoguy!
Run into a snag just post it here.
Mike
Sep 01, 2008 | Gigabyte Computers & Internet
SATA HDD
you need to install the drivers for it when loading windows,,
you are on the right track by pressing F6 however you need to have the FLOPPY DISK that came with your mainboard in the floppy drive..
If you dont have the diskette then ,, the drivers are located on the mainboard cd,, its in the sata / raid folder, there should be a text document in there with the insttructions on creating a floppy with the driver files you will need.
Jul 19, 2008 | AOpen AX4B-533 Motherboard
Gigabyte GA-7VM400AM Motherboard Logo
170 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
