Question about Pioneer DVR-720H-S DVD/HDD Recorder
The disc tray doesnt open. What should I do? - Pioneer DVR-720H-S DVD/HDD Recorder
  • 11,896 Answers
Try pressing and holding the power button for 5 seconds. Or unplug the unit, press power button, wait one minute, replug in and try again. If problem persists, then you may have a bad door motor or a faulty capacitor in the circuit.
Posted on Sep 28, 2009
Yes when I try to open the Xbox 360 disc tray the power button in the center flashes as if the disc tray is opening, but doesnt open. it flashes even when i havnt pressed a button for it to open the d
Try turning off the 360 then turning the xbox on its side, turn the machine back on holding the eject button and the power button together for about 30 secs then the machine should function normally
Jun 19, 2014 | Microsoft Xbox 360 Console
Tip
If the disc tray doesnt open then follow these tips
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Aug 28, 2008 | Samsung DVD-V4600 DVD Player/VCR
Model fw-c555-01 problems opening
You get the tray out by releasing the retainers. Then cycle the unit so it is in the eject mode position and with the power off on the unit insert the tray so that all the gear mesh and the tray can go all the way in. If it goes partially in then the mechanism must be adjusted so that the tray can make it all the way in. Turn on power after than and check in and out before using a disc. If the unit does good with no disc then use a test disc just in case there is still a problem.
Dec 26, 2012 | Philips Audio Players & Recorders
My games wont play and it says open tray
You have dirty laser or bad laser or dirty disc drive period. Try cleaning laser with qtip. If that doesnt work keep the disc drive apart and hook it up to the 360 make sure not to let your disc drive ground out anywhere on the 360. Hit eject button and close tray seeing if the laser even goes up with the tray. If it doesnt try greasing the rails and gears in there where everything slides.
Nov 20, 2010 | Microsoft Xbox 360 Console
Disk tray is not spinning
The way to fix this is to open the disk tray and blow inside for about thirty seconds getting the dust out of the way of the laser also blow across the disc tray and the surface of the disk. Then keep closing and opening the tray and it will start to read hopefully. if this does not work go out and buy a disc cleaner. it looks like a disc with sponges on it and when you insert it into the console it cleans the inside for you. Sources: i am going through it right now internet my personal experience
Apr 08, 2010 | Microsoft Xbox 360 Console
It wont read my disc it sits there and doesnt attempt to read any disc it says open tray how can i fix this?
Ahhhhhh This is a fun one! Ok here is the first thing you should do. Put a disk in the tray and keep in mind the position it is facing. Close the tray and wait for your system to say open tray now open the tray and examine the disc. Let me know if it is in the same position and we'll go from there!
Mar 14, 2010 | Microsoft Xbox 360 Console
Xbox not loading games, no error message,just open tray. Worked last night.
Try blowing the Cd rom out with tray open might just have some dust on the eye if that dont work keep opening and closing the Disc tray is that doesnt work call xbox ( 1-800-4my-xbox )
Sep 20, 2009 | Microsoft Xbox 360 Console
Power symbol on power button keeps blinking green and doesnt stop and doesnt open the tray or read discs
You might want to ask Xbox directly for this one.
Call them at (800)-469-9262
Email them here
Or use Ask Xbox
May 21, 2009 | Microsoft Xbox 360 Pro System Console
Jvc xv-thc3 tray is frozen
The changer mechanism needs to be manually reset. Maybe due to a broken gear.
Oct 28, 2007 | Audio Players & Recorders
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Pioneer DVR-720H-S DVD/HDD Recorder Logo
78 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
